I am having this unusual high memory usage recently, and multi-task on my desktop is extremely difficult. RAM usage hover around 25% constantly on bootup, and 50% just with Chrome browser (12 tabs) running in background. That was why I was having trouble to keep up with my deal post for the past few days.
I tried a few registry reset methods for memory leak issue but no luck.
I already have plans to purchase a new setup this next month, but i wish if there is some expert in here to provide a quick fix before the new system arrives. I am currently running Windows 8.1 Pro on my desktop.
Take a look at the Details tab to find what programs use so much memory.
Some programs (I remember Firefox) take as much memory as they can get but give it back if any other application needs it. This alone is not necessarily slowing down your computer.
there are so many factors to consider so it would probably be helpful to tell us a little more detail about the computer:
OS: win 8
CPU:
RAM: 8GB
GPU:
GPU Driver Version:
are all windows 8 updates installed? There was a memory bug in windows 8 that was fixed via update.
from the resource monitor you should take a look at the processes to see if it is one process hogging the ram. googling the name of that process in addition to keywords like ram usage will probably allow you to narrow down the issue.
has the system been checked thoroughly for malware?
do you run any extensions in chrome?
and finally are you using the newest version of chrome?
Not a expert, but from my googling thats about normal for Windows. Mine sits at 20% with Firefox, task manager open and a few other background programs that aren’t windows related.
Make that 19%, just closed adobe creative cloud.
Edit: ohhh hahha I was looking at my task manager not what you posted. 50% seems higher then what is considered normal.
That task manager picture doesn’t look too bad. The memory usage seems fine. CPU usage, fine. No high disk activity.
When are you seeing things crawl? Have to tried a different browser, such as Chrome?
I found that the best thing I did for my computer was to add a SSD to it, and run windows and programs off of it. That has the biggest improvement in speed.
I didn't notice this problem until I saw Windows tried to access my slower 3TB hdd as virtual memory. RAM can reach 90% where CPU is only around 20%. Pretty odd right?
In the past, i do not have much problem running Chrome with 20+ tabs, Lr, Ps, Ai, Excel, Outlook, Skype, youTube all at the same time.
8 gigs of total RAM seems awfully low. I got rid of my last dell running 7. It would barely function with 8gigs. My newer system has 32 gigs with an i7 processor running 10
8G RAM isn’t all that bad depending on what you are running. I am running 4 Win7 and 2 Win10 virtual machines at home and I don’t allocate more than 3.5G RAM to any of them. I also have a physical Win7 box with 6GB and it runs just fine. In fact I can run a Windows client allocating it 6GB and the physical PC works without issues.
More memory helps of course but you’d be surprised how slow a PC can run if you have a run-away process on it. My main PC has 32GB RAM and I can make it crawl by running badly written software on it.
You really need to provide a screen shot of the Process tab and order it by Memory. At that point you can see what is consuming the most memory.
In my experience the typical hogs are Chrome (and 50% is a lot) and it depends on what the tabs are doing, 2) Windows updates (searching or downloading/installing), 3) virus software (recently Avast went crazy on me on a PC but I fixed it by uninstalling and then reinstalling it, 4) Windows backup programming running or trying to run, and 5) multiple virus software running on the PC (2 is not better than 1).
If you open the Process tab look for things that are consuming a lot of RAM. You can right-click on it and then go to the actual service that’s executing to see what it is. You can also kill the service and see if that makes your PC run better (and killing a service from the task manager will not persist into the next start up).
See if trustedinstaller and svchost are consuming a significant amount of RAM. These programs are used for installing Windows updates and can make your PC slower than dripping molasses on a winter day in the Artic
Do you know what programs or services are starting up when the PC boots up? You can run msconfig from a DOS prompt to see and also post a screenshot of the entries in the Startup tab if you want more analysis on it.
You can buy nice used computers on EBay for the cost of the RAM.
I just took delivery of a 16GB i5 3470 Quad Core with a 500GB WD Black drive in an HP6300 SFF case for $199 delivered.
Had Windows 7 Pro installed. I won’t touch anything above Win 7.
BTW, dating all the way back to Windows 98, I would just put my old boot drive aside every few years and do a new complete install on a new drive. This after I would experience the kind of problems you mentioned. Easier and better than trying to figure it out sometimes.
I am also running at 4.5GB memory in use on Win8, but there is 32GB available on this PC.
If you look at Processes tab within Task Manager, click on the Memory from there. You will see what programs are using the most, listed from top to bottom.
For Me its Chrome with 17 Tabs open in it. where Chrome is listed 17+ times, each sucking resources.
With a clean install of Win8.1 you will need to provide a valid license. Not a problem if you have it but an issue if you bought the computer pre-loaded with the O/S. An option is to upgrade to Win10 which is still doable if you qualify under the assistive technology program. It is basically an honors thing and it is up to you to decide if you qualify. If you have an activated Win8.1 O/S then it will upgrade seamlessly unless you have non-Win10 compatible devices.
But to be honest I don’t think it would take much effort to fix your slowness issue. Some of the suggestions here are good but some are on the other end of the spectrum based on my experience working with computers (which is what I do for a living).
Chrome OneTab extension may be useful when trying to save memory. It is also good to check that your machine is not used to mine cryptocurrency like Bitcoin by some other party so something like Chrome minerBlock extension may be useful.
