Yea does a high amp battery like a 45amp push a LED that only needs 15amp to hard or does the LED only draw what is needed?
Trying to figure if I need close to amp numbers for my lights or will higher amp work better due to the light only drawing what’s needed? Don’t want to damage LED if higher amp battery will push it to hard.
the driver will decide how much current the LED needs.
having a high current battery only ALLOWS high currents - if needed.
a lower current battery may wimp out before the driver does.
When the driver sees that, it may reduce demand to avoid under-voltaging the battery [which means it is over-currented]
also drivers may monitor temperature [in various ways] and reduce current to avoid LED damage due to heat.
wle
