I’ve recently been buying far too many Sofirn and Astrolux torches, mostly thanks to this forum… Love the SP36 BLF and SP70.
However I want to get my parents / inlaws some good torches and those aren’t really suitable.
So ideally what I’m after is a torch (doesn’t have to be Sofirn) that has the following characteristics… does this perfect torch exist? Basically a lighter single battery version of the SP36?
USB chargeable.
Good flood, doesn’t need to throw hundreds of meters.
Lithium ion battery, eg 18650, 26650 etc.
Long battery life.
Ramping.
Thanks
There is the Convoy M3, only thing it doesn’t have USB plug. For the money, it’s hard to beat.
Astrolux S43S?
SP32A if you can get by without USB cable charging
SC31 if “ramping” is less important than being rechargable
Both use single 18650
Just an update, and thanks for your comments… :slight_smile:
I decided to skip the Convoy as USB charging was a biggy, these are going to old people who’ll forget to take the batteries out and charge them separately.
I went ahead and ordered a Astrolux S43S, plus a 18650 tube… so will be keen to see what that’s like…
I’ve got a SC31 and an SP32A, but already had more SP32A on order as I did like those, despite the separate charger required.
Still keen on any other recommendations though…
Got my brother (muggle) an S43. After getting past the instruction booklet, suited his needs very well. Always stunned at the the turbo output. Gets hot fast, so feels an obligation to lower the setting - a positive feedback to the light.
Plugging those requirements into the database basically finds just 2 lights: the Thrunite Neutron 2C and the Thrunite T1. Either of these are around $45 but the T1 is smaller. Both are good lights and have a neutral white option though Thrunite tends to use weird neutral whites.
D4
D4S
E07 (21700)
S43
etc…
don’t have to run a light on max. E07 would be my personal best if Fireflies wasn’t known for massive qc issues and poor support. I use my D4 below the first ramp flicker (>400ma, high efficiency) and it lasts longer than all my other lights while still providing more lumens
edit: but these aren’t usb rechargable, I think it’s expecting too much for usb charging and limits your options considerably.
Simple ....A 10$ Boruit R2 headlamp
Get rid of the strap , add a piece of diffuser film to the lens if you want more flood and glue on a nice rubberized magnet to the flat side .
I gave one to my mom and have one attached to the side of my refrigerator in my kitchen ..use it all the time . The color is ok and for a normal human it's a lot of light . ramps , has motion detection and usb charging . what's not to love for $10.
Also the Boruit D10 is a great /maybe better light ..but no ramping .
+1 on this. The Thrunite 2C V3 is one of the few stock lights I have in NW. What’s also great is that it can take 18650’s and 18350’s out of the box.
not yet available, but the BLF LT1 would suit you. 1-4 18650, usb charging, ramping, tint mixing, and very floody. It’s more of a sit on the shelf light, but at least one prototype user tells that she uses it often.
I have one of these but cannot seem to find them for sale now.
Do you know where to find them, Boaz?
The S43S will get very hot. Please inform the parents to be very careful with it.
Sofirn SP31. noobs don’t care about ramping
I like the Thrunite T1 alot, except for the CW tint but I plan to replace the emitter if I have time. The Niwalker MM6S is worth looking into but the current UI sucks and I read they are revising their UI. But it only comes with Nichia 219C so the tint is not great. The Astrolux MF01 Mini should have the SST-20 95CRI, which should be either the FD2 or FA3 tint bin so tint will be better than the greenish 219C 90CRI. The Wuben TO50R is also not bad but the buttons are hard to find in the dark and the Samsung 90CRI LH351D emitter is a bit greenish.
Currently, there does not exist a perfect flashlight with usb recharge, muggle friendly user interface, and good tint/cri in existence. Even ramping and Anduril UI flashlights are not suitable for muggles. They easily click their way into odd modes. For me, I find a flashlight that I like and mod it with non greenish HICRI emitters such as the SST-20 95CRI 3000K, Nichia 219B 9080, Optisolis, and my favorite E21A 9080.
This. :arrow_upper_right:
I’d actually recommend the Fireflies E07 with the XP-L HI option along with a Samsung 30T, and doing a spring bypass on the tailcap to give it even more powah!
Convoy s9, it has usb charging, doesn’t have a lot of power so it won’t melt your hand, but it doesn’t have ramping, if it matters to you
Sidney Stratton wrote: Got my brother (muggle) an S43. After getting past the instruction booklet, suited his needs very well. Always stunned at the the turbo output. Gets hot fast, so feels an obligation to lower the setting – a positive feedback to the light.
Hi.
I have 2 x S41’s with 18650 tubes on them.
One Copper. one Copper/Stainless.
I use on setting 4. 90% of the time. Stays cool
and gives decent round you light when walking.
5 gets warm.
6 and 7. fergit. Unless just for a coupla seconds.
They with an Imalent DN35 are my fav’s outside.
