Does the Taskled Hyperboost driver need a switch?
I just installed my new Taskled Hyperboost driver. I got mt input voltage leads and the leads to the leds soldered. I can’t get it to turn on! Are you suppose to use the pot- and pot+ terminals to a switch? Or maybe the PWM terminal? I searched and searched and searched I could not find anything about this. George is out of town and Im totally bummed! Pardon my ignorance if it is somthing simple.
Ken
It works with just LED and input connected. pot terminals and PWM are optional.
Did you try turning trimpot? Maybe it is truned all the way down.
What LED? What power source?
Are you sure - goes to - and + to +
Yes I adjusted the trim pot to 7.3ohms which is 1600ma. Thats what I wanted. I have 12 xml u2 led wired in series. The leds are working I tested them and checked resistance on all my solder joints and everything checked out good. I am powering the driver with (4) 26650 batteries. All batteries charged full.
Ken
Should work ok.
Driver may be dead. I’m afraid you need George, maybe he can give you some hint.
If not he will ask you to send him a driver to check.
I burned one once and he took care of it. I used thread locker for mounting screws and it shorted something, thread locker can get everywhere :frowning:
