While watching this review on YouTube, I noticed that the TD07’s driver has two inductors: one smaller and one larger, which are commonly used in buck drivers.
Can anyone tell, based on these photos, what type of driver it uses?
One inductor probably belongs to the charging circuit and the other one to the buck driver.
Exactly what I thought, it’s a circuit similar to the one used in the FC11C and SR12. what gets me is that it was always advertised as linear FET
I just had a look at wurkkos’ site and there’s no mentioning of the driver topology.
If this is your pic you’d want to have a better look at this component
and find out what it is as I’m assuming it’s responsible for the output of the driver.
Wurkkos never actually stated it, but some reviewers at launch claimed it was FET. I believe that component you mentioned is the mosfet for the buck switching.
These photos aren’t mine, but I’ll probably take apart my TD07 to find out
Google claims it’s a linear fet driver
maybe @Wurkkos or @Wurkkos_Terry knows
The TD07 graph seems to be a typical FET one:
It’s a linear driver, not buck. That 1Lumen test is mine, by the way. Still, it’s a good light and to get something similar with a buck driver it’s weltool or NEXTORCH for about 50% more.
Great to have the 1Lumen team sharing expertise here! Thanks!
By the way, this was the first not regulated linear driver I’ve seem…maybe a software issue?
You bet. You are correct that linear drivers can perform differently based on:
Battery
The MOSFets used
LED(s)
Software (PWM)
Temperature PID
LVP
Compare the TD07 to the Mateminco LT40 I tested, or the Weltool T15 and you’ll see what I mean. Bith of those hasve linear (FET) drivers, but the Mateminco performs most like a cc/cv driver.
@Sirstinky “Linear driver” usually refers to a linear regulator providing a constant current driver. The TD07 uses PWM to control the brightness and shows the usual correlation between voltage and brightness. It’s more a direct-drive driver, not a linear driver.
Thanks for the correction and you are right. I use it interchangeably because both types aren’t fully regulated (smps-based boost or buck) and rely on either PWM high frequency switching through a MOSFet or a voltage regulator (like 7135) for brightness adjustment (most direct drivers use both devices).
I don’t really understand your terminology…
A linear driver doesn’t need PWM (although sometimes a PWM signal with a low-pass filter is used for the reference voltage). It behaves like a variable resistor.
What we usually call a FET driver is a FET used with PWM, switching the light on and off at a high frequency and variably duty cycle. The current is determined by the overall resistance of the circuit and the forward voltage of the LED.
The 7135 is a linear current regulator, that is usually used with PWM to control the brightness (because it only regulates a fixed current).
It’s still a linear driver. It’s just using linear range of fet to dump the excess voltage as heat. It’s not a strictly pwm driven fet as the fet is never fully open.
