Doming a flat LED to adjust CCT and tint
Un-dedoming it to make it greener seems a bit like getting low-sodium soup and then adding salt. Or getting a woofer and modding it to increase the treble. Getting furniture made from a premium type of stained wood, and then painting over it.
But…
The duv, or pink/green tint, can make a light look like it has a different color temperature. I’ve found that a really low (pink) duv tends to make lights look paradoxically colder somehow, while a high (green) duv tends to make lights look warmer.
Like, a Nichia 219B sw45 (neutral) and sw45k (pink) are both 4500K, but the pink one looks more like 5500K to me. And a 5000K SST-20 looks more like ~4000K to me since it’s so green… though the greenness makes it hard to really call it “white” at all.
When I recently got some Fireflies lights with “rosy” LEDs, the specs say it’s 4500K or 4000K or even 3500K, but the beam looks cold. I was hoping for something like a NTG50 4200K, which looks like a pure neutral white to me, but a 4000K FFL “rosy” looks weirdly cold. Some of these fit right in among 6000K LEDs.
So I could see the appeal of adding something to make it a bit more green. It might make these lights look closer to the color I was hoping for.
Here are some examples of this effect… (small pics because details don’t matter, only color … and I try not to use too much disk space on sb’s server)
FF ROT66 219B sw45 (left) vs FF ROT66 G2 219B sw45k (right): (both are good, but the sw45 looks neutral to me while the sw45k looks more like 5600K “studio lighting” for video production)
Noctigon DA1K NTG50 4200K (left) vs Noctigon KR4 SST-20 5000K (right): (I must say, once again, how much I dislike SST-20 … at first, I really thought this was a 4000K emitter)
Noctigon DA1K NTG50 4200K (left) vs FF E04 FFL505A 3500K (right): (it’s wild to me that that blue beam is spec’d at 3500K … I have to wonder if the label is just not accurate, like if I got the wrong LEDs)
Noctigon DA1K NTG50 4200K (left) vs FF L60mu FFL351A 4000K (right): (the mule beam is a bit awkward to compare since a mule beam dramatically changes the appearance, but still, it seems too cold to be "4000K’)
So I wonder if some of these FFL lights could be made to look a bit warmer and more neutral by adding a thin layer of “dome” onto the flat emitters.
I really, really like the NTG50 4200K. The NTG35 4200K is pretty good too, but more prone to color fringing, so I prefer the larger NTG50 for its improved consistency at different angles.
Unfortunately, I don’t have a way to measure CCT and duv… I just have eyeballs and a camera and a large pile of other lights to use for comparison. But it’d be fascinating to measure some of these to find out if they’re actually what they claim to be, or if I actually got the wrong LEDs.
the sst20 in your pic is the most green one i ever seen. LOL
It’s not the greenest one I have. The 4000K models (even the high-CRI ones) are generally worse. At least at 5000K it’s sort of tolerable. And at 6000K or more it’s even less bad. Cold white Olights at 7000K, for example, are often green enough that they look relatively okay. The greenness and coldness kind of cancel each other out… somewhat.
Here’s the same DA1K NTG50 4200K (left) vs an Olight S2R Baton II, ~7000K 70 CRI (right):
It’s still not good, but I find the blue-green shade nicer than the just-green or yellow-green “lemongrass” shade of a 4000K to 5000K LED with high duv. I’d take this 70 CRI 7000K blue-green LED over any 95 CRI 4000K SST-20 I’ve ever seen… at least when it’s focused. SST-20 isn’t so bad in mule form in a purple host, since most of the green part of the beam shines sideways into the wall of the host, and gets absorbed.
Doing this would be strange a few years ago. But nowadays most high CRI emitters tend to err on the side of being too pink rather than too green–if all one can find is low-sodium soup, then adding salt to improve the taste does seem sensible.
Additionally, I’ve noticed (visually then checked through a spectroscope) that this mod seems to come with a side effect of slightly smoothing out the blue spike and cyan dip. This makes it highly desirable to me, since a bad blue-cyan region bothers me a lot more than slight green tint.
I also notice the same effect. Previously I chalked it up to the observation that lines of constant CCT are not perpendicular to the Planckian locus:
So by dropping duv (while holding CCT constant), the Euclidean-distance projection of a point onto the locus moves in the direction of higher CCT. In the above image, a very pink 4000K actually projects onto the locus as 5000K.
I’ve learned since then that perceived difference in color does not correspond to Euclidean distance on the diagram, and that the diagram has some weird notion of distance that does make constant-CCT lines perpendicular to the locus. But given that lots of folks find a correlation between duv and CCT, perhaps the diagram needs to be revised.
It’s also known that cameras have trouble distinguish CCT and CRI. The W5050SQ5 3000K looks about 200K cooler than a SFT70 3000K, but on camera looks warmer instead.
Some pink-binned LEDs are indeed a bit cooler than specified–the sw45k often measures 4600K or more, while FFL’s 351A 3700K measures closer to 4000K. But this difference does not account for the much greater perceived gap in CCT.
Doming raises CCT “much faster” than it raises duv, so doming (say) a pink 4500K emitter to recover a neutral 4500K is not possible. Instead, to get a neutral 4500K, one needs to dome a pink 4000K or 3500K.
I’m curious, if you can find the time to try:
If you were to continually layer the “dome” to the proportional height at which a classical dome would be, how would that affect the optical/spectral characteristics?
I.E could it potentially bring a lower CCT dedomed 519A up past its original domed CCT? And if so, would there be a way to build the dome to translate the apparent surface image to be SMALLER (more intense) at the base of the reflector level? Concave instead of convex, perhaps? Almost like a pseudo wavien collar, hemispherical but with a shallow large-radialed concavity dimpled into the top?
Because W5050SQ3 and other LEDs are using PiG (phosphor in glass)
The LED I did is the SQ5, which I think uses pressed powder phosphor rather than PiG like the SQ3.
I’m not knowledgeable about phosphor technology–is PiG the same thing as sintered/ceramic phosphor, like the type Osram uses? Also, how do you identify this type of phosphor visually? Translucency and smooth surface? Color uniformity and absence of different-colored phosphor grains?
I can believe that the SQ3 uses this sintered phosphor, because your test shows the phosphor layer as very translucent, enough to reveal the vias in the die underneath. I assume this happens because sintering eliminates most of the boundaries between phosphor particles and reduces refractive scattering, for the same reason snow is opaque but ice (melted and refrozen snow) is transparent.
But for the SQ5, the phosphor looks different–much less translucent, and the top surface is very rough, just like SFT25/40. Furthermore, projecting it with a convex lens shows different-colored phosphor particles, which is inconsistent with a uniform material. For these reasons, I think this LED uses some sort of pressed powder phosphor, not PiG.
BTW, what type of phosphor do you think LHP531 uses? I couldn’t decide because it has many qualities of sintered phosphor to my eyes, but detailed photos in your test suggest very small different-colored phosphor particles.
Photo of the above-mentioned test:
Some additional testing is underway, with a SFT25R 5000K domed and powered perpetually-on by a USB supply, which I measured at a constant 0.7 amps.
A comparison of the beam in a S2+ reflector pre- and post-doming. The doming job was not clean due to (1) very small LES and (2) lack of patience, hence the substantial loss of intensity. The CCT rose considerably, and the tint shifted magenta in-person, contrary to what the camera suggests.
Low duv makes most emitters look warner to my eyes, though the 5000K NTG50 looks cooler. The 4000K “Rosy bin” FFL351A X4 I have clocks in at ~3600K/-0.008 and looks straight-yellow to me, and not much different from my “lost the tint lottery” 4000K FC40 at ~4000K/+0.006; those signs are not typos.
I find domed 519a’s a hair green, and 4200K/5000K NTG35 mix notably warmer (and no more pink) than 4500K E21’s despite the CCT clocking close to the same.
One thing my day job has taught me is how variable and weird human vision is.
Look at where the BBL falls in the CIE graph compared to what most would consider “white”; too warm for blue, too cool for orange, and neither green/yellow nor pink/magenta. You need a lower duv to appear non-green around 4000K than you do at 6000K or 2700K.
And yes, generally anything more than 0.005 away from BBL is not considered “white” regardless of CCT.
Is it an error, or is it merely the manufacturers altering their products to be more pleasing to the majority at the expense of the satisfaction of the minority. Most casuals like a lower duv than even my rosy-tint-loving eyes are into, and you seem to go for dead-nuts 0.0000000000, but you and I are not like the average “WTF is duv?” light-buyer so our opinions have less weight in the design decisions of non-enthusiast emitters.
Agreed on all counts. And maybe revamp CRI while we’re at it!
Both can be true at the same time! In the context of discussing deviation from the ideal spectrum, any nonzero duv can be appropriately referred to as an error of approximation. The motivation behind this intentional negative-signed error term is manufacturers trying to please the majority.
That seems a pretty accurate characterization!
Recently I’ve encountered a major gripe with CRI concerning the SFT70 and SFT40 3000K. Per koef3 testing, the SFT40 measures 98 CRI while the SFT70 measures only 94, and some other sources also seem to register the SFT70 as a bit lower.
However, I own a halogen bulb with this CCT, and find the SFT70 a significantly closer spectral approximation than the SFT40. On a white wall the SFT40 is a bit pale in comparison, while the SFT70 has the soft quality of a continuous and smooth spectrum, which also shows up prominently in my spectroscope as not having a very bright blue bar.
After testing a collection of colored, non-fluorescent fabrics, it is very clear to my eyes that the SFT70 does a significantly better job reproducing colors as they appear under a halogen lamp. Every color was reproduced more accurately by the SFT70, with the only exception being indigo-blue, which makes sense as the SFT40 has a slightly shorter wavelength pump.
I also had a 3000K 519A, which would have fared the worst in this lineup–despite a slightly-to-mildly pinkish tint, it renders wood (and other colors requiring deep/far red) slightly worse than a neutrally-tinted SFT40.
True, that.
And also weirdly difficult to convince people that not everyone sees things the same. There’s a lot of variation in eyes, and I run into a lot of people who really don’t want to believe it.
But it’s hard for someone to deny when they’ve done cataract surgery on one eye and are waiting to do the other… because they’ll have wildly different color perception from one eye to the other. Big CCT and tint shift just by covering one eye or the other. I had an older relative do that recently, and they probably got sick of me asking them questions and having them do experiments, but … it was fascinating to me.
One of my eyes has warmer tint than the other. Didn’t always but as my eyesight worsened (astigmatism & myopia, worse in right eye) I noticed it.
Regarding the negative DUV looks cooler phenomena.
Spectral Violet is colder than blue.
Negative DUV is an abnormally high proportion of non spectral purple,magenta,pink.
Perhaps our brain interprets those non spectral colours similarly to spectral violet, resulting in tints that look colder than the measurements and CCT suggest that they would if they were on BBL.
This method of redoming to correct negative DUV emitters is very interesting, no lumen loss like correcting positive DUV with a filter.
Might have to try this out if the high CRI 73Bb and LHP531 end up slightly pink.
That’s an interesting question, and I’m not sure what the answer is. My guess would be that it’s conceivably possible, but probably messy to do in practice. Also, I would guess that the returns in extraction efficiency diminishes quickly past a hemispherical shape.
Smaller yes, but most likely not more intense than just a bare die. Concave/diverging lenses can make a source appear to have a small virtual image, but the divergence angle of the beam spreads out proportionally, per conservation of etendue. In the end, luminance (cd/mm^2) remains unchanged–both numerator and denominator shrink by the same amount.
However, it may be possible to design the dome in such a way that the virtual image of the LES is largest in a ring around the base, and smallest when viewed on top. This would result in a beam with a fatter (but equally intense) hotspot, and a lot less spill.
That’s a very interesting hypothesis! If I understand correctly, by “spectral” you mean “a color that has a single-wavelength representation”.
Physically it does make sense that spectral violet is cooler than blue, as the former is generated by a higher-temperature blackbody radiator. But in human color perception, my guess would be that spectral violet appears warmer than blue, since violet activates red receptors more strongly than blue does. Back when I had a cheapo 400-ish nm “UV” light, I perceived its light to feel a bit warmer than that of a royal blue emitter.
It would be nice to get LEDs with the same measured CCT with different duv to compare perception of CCT difference–with the existing data, the hypothesis “lower duv looks cooler at the same CCT” is not yet well-supported because lots of low-duv emitters truly have higher CCT than the nominal specification. For example: the 519A 4500K is usually +duv and measures ~4300K, while 219B sw45k is -duv and tends to measure ~4600K, so comparing them does not support the hypothesis.
In fact, this method probably gains lumens due to higher extraction efficiency, plus the higher CCT+duv increasing spectral efficacy (i.e., more lumens per same watt of light).
This was the greatest motivator for me to try this experiment! They are amazingly cheap and powerful R9080 emitters, and are likely to err on the pink side due to popular preference. I wanted them to be more neutral and to be available in intermediate CCTs (3500K, 4500K, 5700K), and expect that this technique addresses both.
It feels apparent to me that the whole study or presentation of “light” needs to be reworked…Currently, the CCT is a baseline, and the exact color/tint functions as a tolerance/wiggle room. Like a “linear” baseline. What if we rendered those tint charts 3 dimensionally? Like in a sphere, 1/3 volume red, 1/3 volume blue, 1/3 volume green, and any given diameter spherical shell contained would be a CCT, or a particular color coordinate and tint? Assuming that as the sphere grows, the intensity of each color/tint coordinate is that much more intense in that region, i.e., red shift is further in red region along a particular shell, pink shift is in the red/blue region, green shift further in green, etc…The origin would have 0 intensity, the further out would be brighter/more intense. Anything along a given shell has the same uniform intensity, and anything requiring a combination of CCT could be averaged in 3 dimensions to get a new point, but we’d have to figure out what values are additive, aggregate, averageable…The color would be represented by a coordinate point, and the intensity by a line segment or shell from the origin
***You could even use a hemisphere, and reserve the other half for anti-light, or shadow chromaticism…
It was an idea I came up with years ago when trying to conceptualize time as an ever expanding amorphous cloud of shells, I realized it would work with alot of presentations because we do, after all, live in a 3d existence…
In a way, it is indeed possible to view CCT as an “x-axis” of sorts, and the duv as a “y-axis” of sorts. There are always many different ways to specify a point in space–for example, in 2D space, you can use Cartesian coordinates, polar coordinates, or weirder ones like parabolic or elliptic-hyperbolic coordinates:
Depending on the context/problem at hand, some coordinate systems are easier to use than others.
What you describe sounds a lot like hsv (hue, saturation, value) color space (which is based on cylindrical rather than spherical coordinates as you proposed):
Note that this space contains more information than the CIE 1931 diagram, which captures hue and saturation only, with maximum brightness value.
As do I. And many don’t want to believe that their own eyes are different than they were decades ago either.
I don’t have the time/access to dig through my pile-o-data but I can say that, at least to me, it’s more like, “Low duv makes a light appear further away from ~4700K”, which makes the warm warmer and the cool cooler.
A lot of these dilemmas have been more or less addressed already - e.g. plot the lights on CIE 1976 rather than 1960 or 1931 to see that the the tints measured as the same small Duv values will be more noticable than they appear on the other charts and more for lower CCT lights than higher CCT lights.
https://luminusdevices.zendesk.com/hc/en-us/articles/4414846186253-What-is-the-CIE-Color-Space-What-s-the-difference-between-CIE-1931-and-CIE-1976
"A partial summary of uses in the LED world is as follows
  • CIE 1931 x,y is used to specify the LED color point and define the bin structure
  • CIE 1960 u,v is used to calculate the CCT and Duv of a white color point
  • CIE 1976 u’,v’ is used to evaluate the size and shape of Standard Deviation Color Matching (SDCM) steps at any color point as recommended in ANSI C78.377 and CIE TN 001:2014.
  • CAM02UCS a’,b’ is used in the TM-30 color rendition rating system."
Source
Those who find this topic interesting would likely also enjoy the excellent exposition of DrJones on the subject:
It goes into more detail than Post 10 above.
7 Thanks
I received my AliEx order that had the Kafuter K-705 yesterday.
I had the perfect emitter to add a dome to.
My S21E Mao Grey has an SFN43 3000k High Cri emitter in it.
It runs around 3700k with a 15° Convoy Beaded TIR and around 3900k bare.
I decided to build a complete, near full dome on it.
I took before opple 4 measurements with and without optic.
So far I have not taken after measurements with the optic in place, as I’d like to cure it for a day or so before installing it.
Here are the meaurements so far without optic.
Anduril 5/10 steps for all readings.
It was only cured for about 30 minutes when reading was taken.
I forgot to take before pics of the emitter.
So far I’m liking the results!
