Don't want to destroy this drop in help.
Hi this drop in ;
what AA hosts can it be used in best?.
I wanted it in a solarforce l2d for 18650, but says it can be destroyed!.
is there an double AA alternative so I can my use eneloop AA pros? Or should it be in a surefire 3P?.
Looking for side switch host if possible too.
This will be a back up light.
Thanks.
Solarforce L2M with one CR123 = 3V and very short.
You could also use the L2M short version with 1x18650 extension tube and put two 1.5V AAs inside with a spacer tube.
Maybe alternatively a rested (after fully loaded) LiFePO4 cell (3.2-3.3V) could be used without killing the dropin? :-/
Do you have this drop in now, or are you contemplating buying it?
Contemplating, but I’m also contemplating buying a drop in with one of those XHP-70 5000k 96 cri.
I really think it would be more worth your while to make or buy a Nichia drop in. I have a Nichia Malkoff drop in (6V) and find it to be seriously underpowered. Yes, it is high quality and top notch construction, but a regular Nichia drop in with a noctigon and better driver would give you more options than the Malkoff, and less money. That’s just my opinion.
Are you with law enforcement?
