doubts on 4.35V for a Convoy s2+
Hi, sorry but I am trying to assimilate some of the information that I read in the forum. I want to know if I can use a 4.35V battery in a convoy s2+ and whether or not I would get a benefit on its output-autonomy.
I have deduced that all stock convoy s2+ mount a Nanjg 105c driver (mine is 8x7135 = 2,8Ah) and according to this this driver accepts 3-4.5V so the 1st question is answered unless I am missing something.
On the possible benefit, it is not completely clear to me because in the driver review I see that its efficiency decreases at increasing voltage, especially over 4.0V (I suppose it heats more and wastes more energy) but I don’t know if this would result in a waste of power from the battery (even if the temperature can be controlled) so no benefit comes from the 4.35V battery at all. What is your opinion? would a 4.35 V battery have any performance benefit on this light compared to a 4.2V of the same capacity? And compared to a 4.2V of higher capacity? where would be the battery capacity threshold where there is no practical benefit?
Do you know any 4.2V battery that has same or higher capacity then modern 4.35V batteries have (aside from Panasonics, that have their additional capacity below 3V and therefore are quite useless for AMC drivers)?
In short, 3000-3200mAh 4.35V battery will drive the flashlight longer (but hotter) then 2600mAh 4.2V one.
I know what you mean but you have to be careful with that, not longer but brighter…or longer brighter…
Because with higher voltage you get more current and more brightness…could lead to smaller runtime at all because a real crappy cell with low voltage would give a small amount of light for a longer period…
Besides that I am a big fan of the LG18650D1, they are the best cells and quite cheap too. :party:
Perfect for the linear drivers.
I have three cells From Bangood on order for a total of 15.65$.
A bit cheaper for a quantity of 6 for 30$ from aliexpress
The same seller has also some protected at aliexpress for 32$ for 6cells…I asked the seller and he said that the overvoltageprotection is made for 4.35V…but I haven’t ordered them because I anyway use drivers with built in under voltage protection.
No.
It would be so for direct drive, but we’re talking about stock S2+ with the linear driver.
Sorry but I don’t get it. Is that what you meant to say? - I thought that was obvious. The question was more if 2600-3000mAh 4.35 batt would drive longer/more lumens than 3000-3400 equivalent at 4,2V and if so, what is the threshold in capacity of the 4.2V battery above which there is no difference with a 3000mAh 4.35V (like LG ICR18650D1).
although the first question is answered…
I thought all Nanjg drivers can take up to 6v?
I had them run off two cr123 no problems (I’m using 18650 now thou, cr123 is ridiculously pricy here)
or am I wrong ._.
What do you mean by “equivalent”? Some theoretical batteries or real ones?
Max (usable for AMC drivers) capacity for single 4.2V 18650 cells is ~2600mAh at the moment.
I meant high quality and top capacity for their type. For example, 3400 mAh panasonics vs 3000 LG 4.35V. Sorry if this is too obvious, I am struggling to understand it.
Panasonic cells meant to be discharged down to 2.5V, and their rated capacity is measured for the whole voltage range (4.2->2.5).
But AMC7135 drivers (like that in S2+) need at least 3.2-3.5V to operate - the exact value depends on the LED forward voltage (higher brightness bins tend to have higher forward voltage) and wires/springs/switch resistance.
So Panasonics don’t fully discharge in flashlights like S2+, only using ~2500mAh of 3400.
LG/Samsung/Sanyo cells give most of their capacity down to ~3.3V, dropping quickly after that.
LG 3000mAh will run longer in S2+ than Panasonic 3400mAh (actually up to 30% longer in certain configurations, but usually about 15%). Even Samsung 2600mAh 4.2V is comparable with Panasonic 3400mAh for this flashlight.
The first thing to note is that an LED’s voltage depends on the drive current. An XM-L2 at 3 amps might need 3.5v or 3.6v and so your regulated run time on HIGH in a single cell light with a linear driver is however long it takes for the battery to hit that voltage level, then the light “falls out of regulation” and will start to dim as the cell voltage drops lower. The Panasonic cells get much of their extra capacity because they are rated down to 2.5v which is not useful in single cell lights. It can be useful in multi cell lights with buck drivers that have good low voltage protection like taskled flex drivers. You could drain the cells all the way in that configuration.
Worth noting is that there is a new LG 4.35v cell in town and it’s 3200 mah and costs less than $8 USD.
Let’s look at HKJ’s comparator to see a protected 3400mah 4.2v Panasonic cell vs LG’s 4.35v 3200mah cell at 3A drain. Notice which offers higher voltage during its useful portion?
Unprotected 3400mah 4.2v Panasonic cell vs LG’s 4.35v 3200mah cell at 3A drain:
Now the new 3600mah protected Panasonic cell vs LG’s 4.35v 3200mah cell at 3A drain:
The difference is not as dramatic in this case but the 4.35v LG still gives higher voltage over a more useful voltage range. The curves compare similarly at 5A drain as well.
There isn’t an unprotected 3600mah Panasonic on HKJ’s site yet but it should perform a bit better than its protected variant.
In Conclusion:
Since the new 3200mah LG 4.35v cells can be had for like $7.50 USD each, it’s the clear winner in more ways than one. Make sure you get a charger that can charge to 4.35v properly.
Thank you so much Alex TG and Hoop for your patience and detailed explanations, I had seen those curves but I didn’t understand the implications. Now is clear and I am going to switch to the 4.35V LGs instead of the 3.400 pannies.
You’re welcome.
I just checked and the pink 3000mah LG’s seem to perform as good or better than the new 3200mah LG’s, at least if you’re comparing run time on HIGH. The voltage difference is even more pronounced at 5A. I had wrongly assumed that the new 3200mah cells were better in this regard. Either cell is going to be a good performer.
Yes, I saw that before I ordered 2 pink ones :wink:
A higher voltage gives higher current…that’s correct.
Especially the nanjg start to dim very fast because they are linear drivers and not regulated.
So if the voltgage of a cell is lower the current is lower also. That would give longer maybe equal runtime on lower brightness.
I already stated in my above post that the LGD1 are the best cells…
Werner, the nanjg drivers are current regulated via the 7135 chips. Linear drivers regulate current; FET drivers dont. The light will only start to dim once the batteries do not offer enough voltage to stay in regulation. With an XM-L2 at 3 amps this might happen around 3.5 or 3.6 volts or something close to that; only once the cell is depleted to this level would the light start to dim.
It’s more of a limiting and no regulating :wink:
And the lower modes don’t stay in regulation at all, because they are only made via PWM…so there is just a percentage of the max current used. For example on a duty cycle of 50, 0.5*maxcurrent. But if the voltage is low than the max current is not the 3A, it’s lower so the 50 are lower too.
A ncrb can maybe give half an hour 3A after that the voltgae is to low and the current gets lower->brightness lower too
A LGD1 gives 3A maybe 45minutes on 3A and after that the voltage is to low.
So it was 15 minutes brighter than the ncrb, okay?
So in that 15minutes it reduced its capacity faster than the, Panasonic ncrb, okay?
After 45minutes the LgD1 has burnt 0.75h*3A=2.25Ah
The panancrb
0.5h*3A+2.5A*0.25h=2.1Ah
That leads to my conclusion(real world shows the same) that the runtime and capacity are not always correlated the way we would think of in the first thought.
Think about a crappy cell with 3.3V but capacity of 3Ah, it could shine longer but on a lower current/brighness.
Yea, good point; the lower modes should also start to dim once the light hits the HIGH mode dropout voltage because it is only PWM that allows the low modes but all modes should stay in regulation until that point.
And that point comes very quick with 4.2V cells….so 4.3V cells give you longer the full brightness….not longer runtime in general…
It gets worse with higher current because voltage under load reduces with rising current.
That leads to the conclusion that if you have a low current application like a ak47nanjg the benefits of a 4.35V cell are smaller than at 3A or 4A+.
Of course just if you define benefit as a longer maintained full brightness and not runtime in general…
Of course it’s the matter of definitions :slight_smile:
And yes, by runtime I mean the regulated runtime, and not the silly ANSI FL-1 one (down to 10% of initial brightness) or something even more exotic.
