Shit.
How did you go about swapping the LED? The pads are quite easily ripped off these things.
The pads on the board have limited trace connections to the SMD components, especially the lower right LED connection.
The diaphragm button can be finicky too, clean underneath with good connections through the PCB?
Luxeon v2 has the little circular nik out of the centre pad at the negative side.
