Quick question.
I just finished my first build, Convoy S2+ with the Dr. Jones driver. From what I can tell when I try to set the double tap, it still seems to only cycle through 22 brightness levels.
I have a fresh battery, and I let it ramp all the way up and back, but it doesn’t seem to be cycling 24 levels.
i remember this same insident with one of mine and figuring it out a long while ago i think i read up on the driver on mtn electronics website and figured it out it wasnt a bad thing or problum its just something error in type or something stupid your driver is fine its the same thing mine did just use 21 and 22 as te two highest 23 and 24 are included by the double fst turbo pressing of the button but im possitive they all do what you are asking about mine is same i just checked it i have this driver in 3 diff lights its a great all around kinda can put it in any set up but i moved ontoo higher amp drivers and boost the turbo on that driver is only testing around 6 amp on mine if you want efficiency it is great if you go too direct drive you can get more power the fet on that driver is a baby little cute thing ive had too replace that little thing once or twice trying too pull more power with diff version from rich at mountan electronics and the add too amp was so small hardly noticable but yours isnt wrong i noticed same with mine and it boggled me untill i read somewere thst the other 2 levels are built in u just cant go past 22 bud
Thanks for the reply.
The way I understand fro the mtnelecronics website, if I go into set the brightness on the double tap, I should get the extra levels. But I didn’t seem to see it. It still pauses at level 22.
I tried it to set the double tap also, but didn’t see anything past 22. Are you saying yours does go to those higher levels in setting double tap?
