Driver for Genuine Original Black Sky Ray king V2--Investigation
Hi guys
We are going to make a new batch of Original black king.
I would like to gather some ideas and suggestions from BLF members here.
The build quality of original king is good enough.
Any idea about the driver or emitters would be greatly appreciated.
Should we make some improvement to current King driver?
Should we add more option for the emitters? CREE XML2 CW / NW /WW?
Thanks
RIC
My only suggestions are:
1) Remove the PWM.
2) Give it a medium to make three usable modes instead of just a real high and a real low.
3) Current drive at above 3 or 3.5 amps per emitter would be great.
I have always preferred cool white, personally. XM-L2 with more hollowed out reflectors for slightly better throw would be even better still.
At least 3, I think a few more would be even better (some drivers here are being built with 8-12)
PWM is ok as long as it's a higher frequency, low frequency PWM messes with peoples eyesite sometimes and can cause the components to make squealing noises and whatnot
Well, here's my ideas:
XM-L2 U2 in the 5700-6000k range. Probably about a 1D as well as NW, can you find U2 in the NW range? No XM-L2 T6 leds, find whatever you can in the way of XM-L2 U2 leds, are there any U3 coming out yet?
The three toroid driver is fine, but it needs to have high mode of 3.5 amps per led. That should be a resistor change and it needs to be verified by checking amperage at each led, because there in imbalance in that driver, so it will need different sense resistors for each leg. Not a turbo that shuts down on a timer, but a true 3.5 amp high that we can turn down when we want to.
5 modes, moonlight, low, medium, medium/high and high. moonlight will probably end up about 2%, then 15%, 35%, 65% and 100%. Or close to those levels. Hidden Strobe please. Last mode memory too. Start on moonlight and cycle up to high mode.
The leds need to be on Copper Stars. Real direct to copper on the center pad, like the Noctigons are.
Tail caps should not be glued.
Bezel and Button need to be polished Stainless, not Aluminum. Highly polished would be nice.
Old-Lumens has spoken :D
I vote for what he said
Old Lumens has the best idea …
Yup, that about covers it. I would buy one. 8)
I vote for much the same as OldLumens, but I know many of them will increase the cost with all these options.
But the main ones i would like to see is:
- No Pulse Width Modulation on any modes.
  • At least a 4-mode driver minimum, ( Moonlight, Low, medium, and High) The High should be around the 3 Amps per emitter range.
- Definitely XM-L2 U2’s (on copper if the higher Amperage is given to the Emitters) offered in three tint ranges, a Cool White in the 5700 - 6000k range, a Neutral White in the 4500k range, and a good Higher
CRI WarmWhite version in the 3500 - 4000K range.
- The same Stainless Steel Bezel as the original SRK.
  • Offer it in the Black or the Gun-Metal Grey mode.
If all these were added to a new SRK, i would be interest in ordering a fiew.
Yep what O-L said.
I never owned one SRK, but i remember people complain about that rattling switch that isn’t of the best quality. But i would be in for one if this goes through!
Yes, what Old Lumens said except I’d rather it start on High. Either way not a deal breaker though…
+1 for Old-Lumens light. It must have mode memory.
IMHO l dont think this would make a good MTG-2 host. It will not get rid of the heat and MTG-2s need big reflectors to focus the hot spot for a floody by design led.
I was just foolin around, and putting ideas in peoples heads… :wink:
OL’s setup seems pretty good
If you made it 2m dunk-proof, me:
Five modes seems like a lot to cycle through all the time. Could we have a two-group driver for that instead?
Group one: 3.5A - 1.0A - 100mA each led
Group two: 20mA - 100mA - 1.0A - 2.0A - 3.5A each led
Hidden strobe accessible any time I want to blind my friends attackers.
In that order, with group memory only. Because sometimes I want to start on high, and sometimes start on low.
I like all of this, except for the 5 modes. 3 is pretty much my max when I have to cycle through them to turn off.
I would be fine with 5 if it's possible to get it to turn off after a 1 second press and hold.
Higher high. Get the moonlight/low as low as possible. Throw some modes in between.
smells like group buy to me…i would be in if it is “BLF approved” :smiley:
if you let choose the emitter it would be nice (like banggood on most convoy light)
highest bin for respective tint, XM-L2 U2-4C appeared on fasttech, it really exist?
For the driver, the ld-35 used in Roche M170 seems fine to me, no PWM and stepless ramping. Maybe it lack a moonlight mode.
Old Lumens suggestion are nice but maybe the price would not be the same.
Im not buying any more lights …except the one OL suggested.
like OL said, but then the way around.. Who wants to have this kind of light Starting in Moon-mode?
If you use this light, you use it for power... so starting in High (maybe not Turbo) would be a good idea.
Friendly UI:
Have a hidden (double click) Turbo, accessible from any mode and OFF.
From OFF position... double click to Turbo.
From OFF position... press and hold 1 sec for Moon mode.
No visible PWM.
Are we talking about the 3Led or 4/5Led?
