looking for a 17mm driver to run one of these:
any thoughts?
thanks,
Mick
any thoughts?
thanks,
Mick
Me too! I only know of RGBW drivers.
you do not need special driver, any led driver with open circuit output protection, will do, i used such drivers for rgb many times, you just need either an extra circuit, to cycle between colors, or rotary switch to do the same, or any other switch with 3 positions.
or if you can’t use extra circuit\switches in your build, you can get rgbw driver from hank, at intl outdoor. but they are limited to 700ma per die.
http://intl-outdoor.com/mce-color-and-dynamic-white-17mm-driver-p-686.html
mtn electronic has them too as well
just used the one from mtn electronics, and left the connection for the white led empty so it serves as an off position.
