Driver for Solar storm X3 xml-U2
Hi guys.
I’m new to this forum, So please excuse me if I have posted this is the wrong section.
I purchased a Solar storm x3 Xml-u2 bike light, But the driver has failed.
Failed within the first day.
The stock driver is labeled HND-3U9920-V6.
Does anyone know of another cheap driver that will fit this light?
Would really like to install a new driver and get the light working again as its an awome light!
I tried searching, But found nothing.
Must be cheap, Because its a cheap light. No point spending 20$ on a driver when the whole light only cost $25.
Any help would be greatly appreciated.
Hi and welcome Aussielight. I dont understand the electronics but looking at you picture it appears that the R2 resistor has burnt out (copied the picture to my desktop to see this).
Hi.
Yes, R2 gets super hot. I noticed it was burnt but still checked good on the Multi meter., I tried another resistor, But it also got super hot fast. Must be another faulty part causing it.
Probably one of the IC’s. Which if that was the case, I would not bother changing out as i would have to wait a month for parts, And you never know it may fail instantly due to another issue.
Also, U2 gets very hot within seconds of pluggin in battery.
Im not smart enough with small circuits to try and fix it. Would just rather try a better driver all together.
Every time i try repair something, It just fails immediately due to other faulty parts.
I just really hope there is a driver out there that will fit.
I think its toast.
Are you just using the stock battery pack?
Hi, Yes and no.
I have the stock 4x 18650 that I used at the start.
But I plan on using my rc truck batteys with it.
Zippy Flightmax 5200Mah 2s 40c.(7.4-8.4v) for better run times/more capacity over the stock China 18650’s.
The zippys are compact, excellent capacity, and way better quality.
Why don’t you contact the seller to get a refund or a replacement if it failed on the first day of using it, or have you had it for a while? :slight_smile:
Hi.
I got a part refund of $8 .And kept the faulty light.
He wanted me to post back to China which would have cost me $50 shipping to get a full refund of $29.
No one knows of a driver that will work?
If you rewire two of the LEDs to work in series, you can use a Zener-modded driver loaded with momentary switch FW. Better would be a driver with LDO instead of the Zener diode.
Hi, sorry, what is LDO?
Ideally, I’d love to keep the push button now you mention it.
Also, All 3 LED’s are already wired in series. For a total requirement of 8.4v.
Slightly off topic for a sec, I saw some drivers, They say 5 mode, Yet have no button, How would you cycle through the modes with no button?
Does the driver just change modes every time the power is cut/applied?
Having a further trawl for drivers that will fit(hard part) I see the single rounded drivers, possibly may need to try 1 or 3 of these. If they will fit, probably not though.
Although, Most drivers I saw were for ~3v for a single cree LED, Not 3 in series.
I can not believe, For such a common china light, They have no spare drivers…
I purchased on of those 15000lm 9x cree u2 bike lights, Expecting it to smash the solarstorm x3……Not what I was expecting….
Those 3x cree solarstorm u2 lights a awesome! Just as bright as the 9x U2. I would love to get it up and running again!
I guess any step-down (buck) (with choke) (boost drivers also use chokes, but those are rare) driver would fit your light. Check for example http://www.kaidomain.com/Category.226/2/40/releasedata/
this http://www.kaidomain.com/product/details.S023801
or this http://www.kaidomain.com/product/details.S023147
If those fit in size.
Or may be it is simplier to buy another , like
http://www.ebay.com/itm/111629777395?\_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
or http://www.ebay.com/itm/7500-LM-SolarStorm-3x-CREE-T6-LED-Bike-Bicycle-Light-Lamp-Headlight-Just-Lamp-/121604658058?hash=item1c5033d38a:g:n88AAOSwstxVEial
I think the driver is same there.
And buy the way most probably these lights have fake cree leds (aka LB).
You might find much info regarding these fake LEDs.
So to get really good light consider modding it (changing LED, MCPCB, and probably driver).
Regarding your driver:
http://postimg.org/image/m456t26s9/
At this picture I put some lables to components.
So most probably step down controller is faulty, or may be FET and step down controller (FETs in this package are not very powerfull).
Off course zener wastes a bit much power, but it is not critical.
” somebody set up us the bomb”:Urban Dictionary: somebody set up us the bomb
Hi Pro22000.
Thanks for taking the time to edit the photo with descriptions of the components, Makes me understand the driver much more.
I thing you are right, The step down controller gets super super hot immediately after power is applied. So it is obviously faulty. Far to small for me to try replace, Plus I can hardly see the part numbers on it.
The sense resistor looks to have cooked for a few seconds too.
Driver is just toast.
I always wondered what the coil was(choke)
I agree, the new 9x cree light must be using fake cree’s. But the x3 may be using something much better, As it is so damn bright! Brighter than my car headlights.
Shame, after having the x3, I was really excited to receive the x9, But I was disappointed.
The driver in the x9 looks crap. Worse than the x3 driver.
Here is my Solarstorm X9 u2 light driver. (You can now see why i called it crappy)
Can anything be done to mod it for more output?
Upgrade the crappy diodes?
Something else?
That actually looks better than the broken X3 driver because the FET is in a bigger package.
It looks like the sense resistor is next to the FET and labeled R200, which means its value is 0.2 ohms. Replace this with a smaller value resistor or solder a low resistance resistor on top to increase the drive current.
I’ll go down to my local electronic store and get some resistors.
What size would you recommend? A .01 ohm or lower?
Is that just a 1ohm resistor?
Replacing .2 ohm with .1 ohm will double the current. If you can find a small wire wound potentiometer with low value, connect it in parallel with existing .2 ohm resistor. Then you can adjust the current.
OK, I’ll go and see what I can find at my local jaycar(elec store)
But, May have to look online as I’m not sure they will have anything that small.
Something around .2 to .13 varable.?
Only want to bump it up slightly, as cooling does not look to good.
