Driver for XR-E Q5
Good morning!!
Playing with some Q5’s, and I’m using the Kaidomain V2 1520mA drivers.
Looking at some of the data sheets, the XR-E likes more voltage than the XM-L, and the KD V2 driver seems to be designed for the XM-L.
Can anyone suggest a better ?boost? driver, either single mode or moddable to single mod, that will give the brightest output?
The star is on a good size brass pill, and is used for maybe up to 5mins at a time.
Battery is a single 18650.
How about going direct drive on it? Been done successfully by others.
Don't the Nangj drivers pass through whatever voltage the LED wants (up to the driver's max)? So if the LED only wants 2.8v, only 2.8v passes through, but if it wants 3.2v at higher amperage it pulls 3.2v through? This is my understanding - that the Nangj drivers control current, not voltage.
I'd say that driver is fine, although you could step up to the 2.2A one for a little more kick if you wanted.
-Garry
Both previous answers are correct.
You want brightest output and single mode. The answer is definitely direct drive. Better yet, this driver is FREE!
Noob question. Actually, what is the highest drive level (current) that you could run a Q5 on without frying it?
Depends on heatsinking. ;)
2.3A are stable.
E's been doing Q5 at 2.7A (or near that) and have been having good results.
I do 2.2 on mine with no problem at all, no heat issue.
No, E uses R2. Those seem to withstand a lot of abuse. P3 to Q5 are the bins you usually find in most cheap ebay lights.
Thanks!
Sheesh…. I notice both my Q5 flashlights are only running at about 1 - 1.2 amps. That means they’re hopelessly under-driven :expressionless:
Well.. a little. ;) But they wont get twice as bright with double the current.
