Driver help!!
Hi, I’m planning out my first build with the p60 platform. I’ve decided to use a cree xpe bgr L1 powered by one 18650. I seem to be having trouble deciding what driver to use. Can anyone point me in the right direction?
Any reason behind using an XP-E? There are much more effecient Emitters available. The XP-E2 or XP-E2 torch LEDs are just newer versions of the same thing.
That being said, for the plain XP-E, get a Qlite driver from www.mtnelectronics.com and get it with 4 chips removed to avoid toasting the LED. For the XP-E2 or torch, only remove 2.
You can remove those chips yourself if you feel confident in your SMD soldering skills. Otherwise just get them predone
