Second, I would like to swap the original driver with a 3 mode better driven one, but i dont have a clue on what driver to use to get both AA and 14500 options (because of the voltage range), and the size i presume it is 15mm because the pill is almost 16mm diameter, a bit less.
I think you can notice actually, the beam angle of the XRE is 90 degrees, XPE is 115 degrees, zoomed out the emitters may compare well, but zoomed in much more light of the XPE will be trapped inside the flashlight compared to the XRE. I have no numbers but my guess is at least a 30% difference. That is also one of the reasons why XML leds perform so poor in zoomies.
I actually used a small knife (or something sharp) and press it hard anti-clockwise and got it to unscrew (you may notice the marks on the aluminium), but i will make a couple of grooves on the pill to ease unscrewing next time!
Unscrewing “sk68” pill with no holes: Clamp the pills edge and sliding outer zoom ring together (I use my fingers if they are loose enough) and rotate counterclockwise.
I am afraid not, if the efficiency bin is the same (e.g. Q5) flood and throw will both be worse than with a XRE, with throw more so than flood. Perhaps on the bright side: all my XPE's have better (less raw cool) tints than my XRE's.
i placed a 4-mode driver in one of my SK68s. ( High-Medium-Low-Moolight ) only works with a 14500 though. (the 17mm 105C ) or you can use the 20-mode grouped driver ( 7880 ) which works on AA 1.5 volts only.)
