Got some stuff from FT today. Got up to my two-story apartment and two of my green unprotected Panas took a dive over the rail and onto the concrete. There is some noticeable but very small marks on the top of the wrapper. The other landed by my feet. Both seem fine.
I know I have had problems with dropping batteries and protection circuits getting messed up, but in this case, should I be worried? How tough have your batteries been to drops in general?
I have dropped some but not from that height onto concrete. maybe do some load tests and charging tests to make sure they are ok. (any visible large dents in the casing though would be worrysome for internal shorting & venting.
Having been doing tests on pannys . One on occasion one unprotected panny cell did a header from 4 1/2 feet. Now whether it was very hot at the time exacerbated the situation I don’t know.
But that cell after its meeting with concrete, did have a noticeable difference in both internal resistance and capacity (as measured) IR more so and definitely above measuring variance. Capacity IIRC (don’t have the figures to hand) was affected less but still there after several use cycles.
So far no other consequences have been noticeable apart from a slight difference in temp while charging and high amp series discharge, against it’s ‘set’ peers. And a difference in how it charges while balance charging.
Pannys are very resilient against abuse, but one thing that has made a difference in the short term is by being dropped. Now exactly just how damaged your cells are from I presume 12 –15 feet drop, is very difficult to say, too many variables on how it lands.
I would at the very least measure IR and discharge capacity against their set peers. And keep a close eye on how they charge. But even I, unless they were for testing purposes would consider it wiser to put it down to experience and lob them into the bin. Sorry
You have to weigh the risk against the cost, is it worth the possible consequences to keep using it vs. just recycling it and purchasing a new cell?
Some people are cheap at any cost, regardless of risk. I worked with a guy that rode a Harley when they made it law that a helmet was required while riding. He asked if I had a spare I could sell him cheap, which I did. A nearly new open face that I sold him for $10. He crashed his bike, hit his head on a concrete curb, and the helmet split in half front to back, right down the middle. He was fine. He wanted his $10 back because the helmet broke!!! I, of course, wouldn’t refund him because the helmet did it’s job. He superglued it back together and kept using it.
If he wrecked again, wearing that helmet, would he end up in the hospital with head injuries? Risk vs. cost.
A cell that’s known to take a hard blow is a cell that is likely to be compromised. The layers inside are wrapped tightly in a coil, with a blow to the outer case (dent or no dent) these coils and their tight structure can be displaced, causing a short or near short which can then turn ugly when charging, or even discharging. If it means nothing to you that you could possibly blow your hand off or burn your house down, by all means…keep using it. (as long as it’s YOUR house, not an apt where the entire community is endangered, and even if a house you own, how close are your neighbors?)
If a few bucks for a new one gives a higher degree of that not happening, I’m for spending the few bucks.
My memory is so bad I have to toss stuff like that helmet story out there whenever it shows up, who knows if I’ll ever recall it again…
Besides, it was kinda relevant. The imagined degree of safety with the new, undamaged product versus the known possible dangers of same product after a good knock about.
