DRY Driver Questions
Hi guys
I've got a couple of questions regarding the DRY driver (LMHT) and are hoping someone can shed some light onto the topic :D
http://www.cnqualitygoods.com/goods.php?id=1349
Questions:
- The modes are specified as 0.1A, 0.5A, 2.25A and DD. Are the LMH modes regulated? Or are they limited like on the 105C and other 7135 based boards?
- If the current is regulated, is it possible to change the sensing resistor for higher LMH values?
- If the current is limited by 7135 chips or similar, is there a way to increase the LMH values?
- Is there an upper limit on the current in DD? What is the maximum the driver can handle?
- Does the driver act as a buck converter, or does it require the output voltage to be similar to the input voltage?
- Will the driver work with 1 x XML and 1-2 x 18650?
Thanx guys
I can say that I like the levels/modes on this driver but I get a slightly audible hum/whine in every mode. I have tried everything to stop this, including adding ground leads, changing out switches, etc. It is a great value and driver if you can deal with the noise.
I'm pretty sure there are some threads on that... I forgot a couple of details, but according to my memories all modes are direct drive, but modulated by PWM. The current mainly depends on the battery, and there's no resistor modding.
Thanx guys. I'm planning to do a MT-G2 build with 2 x 18650's and use the DRY driver with this build, as it would give me a nice usable 2.25A in high, and 7-9A on DD. I just wanted to know if there's a way to get a medium of say 2A, high of 4A and DD of 7-9A.
2.25A is still a whole bunch of light from a MTG2. I think the as-is mode spacing sounds about right.
I agree. Visually, the spacing is pretty nice.
What code is printed on top of the original transistor installed on the DRY driver?
Is there a better transistor to replace the original ?
