EA8 clicky button spoil?
Hi gurus,
Have EA8, the rubber button that will give out blue light {when batts are installed} seems to be stuck, “cannot be depress”.
Is the clicky switch spolit?
i cannot even tear it apart? :smiley: even tho it seems so easy…
1) Lens top the sliver/grey cap i cannot get it open, no tools or tools not big enough to “go into” the grooves to turn.
2)Vice clamp the body, F & G clamp the head but cannot seperate the body & tube…
I thought of lockout mode, but problem is , i cannot depress the switch at all…
Look for Old Lumens EA 8 tear down.
Bezel should b removable.
From there you can take everything out.
