Eagel Eye X6 - XPL HI
I just picked up this light and it is a fantastic small thrower with the XPL HI emitter. This is my second Eagle Eye light, and they really provide a lot of value for their price point.
I do have a question that I hope someone might be able to answer. I have been searching online, but cannot determine if the light has a low voltage warning. Does anyone know one way or the other? Thanks in advance!
Regards,
Frank A.
View post on imgur.com
Depends on the driver (of course)
It probably has low voltage warning and shut down.
Yes it have lvp at 2.8V, also there is a 3 min step down from turbo since this light is pulling 3,55A stock. Only problematic part is no O ring in front of the glass so waterproofing is not ideal.
Btw my favorite flashlight for all time !
the o-ring will be waterproof the reflector is designed to push it against the tube wall
Not functional at all, tried to put it in the kitchen sink and water penetrates easy…
So I found the 35/33mm 1 mm thick O rings on Ali and install it in front of glass. Now you can even dive with it :smiley:
strange my X6 were watertight
