Features
•Cree XM-L 2 (U2) LED with a lifespan of 50,000 hours
•Uses one 18650 rechargeable Li-ion battery or two 3V CR123A Lithium batteries
•139mm (Length) x 25.4mm (Diameter)
•87-gram weight (excluding the battery)
•Digitally regulated output - maintains constant brightness
•Low-voltage warning function to remind you to replace the battery
•Reverse polarity protection guards against improper battery installation
•ver-heat protection to avoid high-temperature of the surface
•Anti-roll, slip-resistant body design
•Tactical tail switch with momentary-on function
•Side switch on the head
•Made of durable aircraft-grade aluminum
•Premium Type III hard-anodized anti-abrasive finish
•Toughened ultra-clear glass lens with anti-reflective coating
Operating:
Unscrew the tail cover,the anode of battery toward the direction of the LED ,then tighten the end cap.
Touch the tail switch can open the flashlight.Pressing the tail switch completely can open the flashlight and lock it.And pressing again can close it.
Click the dimmer button on the side of the flashlight head,you can control the brightness of the light circularly:Turbo; High; Middle; Low; Moonlight
Pressing the dimmer button for 1 seconds,the flashlight will enter flash mode. Click the dimmer button can back lighting mode.
Pressing the dimmer button for 2 seconds,the flashlight will enter SOS mode. Click the dimmer button can back lighting mode
