My X5r won’t charge correctly (or at all). When I plug in the micro USB (have tried at least 10, with different wall chargers), the light turns bluish purple when I turn the switch on….NOT RED like it supposed to. And it won’t charge. I’ve had no problems charging the battery on a cheapo 18650 charger, but it refuses to charge correctly while plugged up to a USB wall charger of any kind. I’ve tried 1amp, 1.5, 2amp……same thing….just a purple glow coming from the mode switch.
I’ve also seen where someone took their battery out during the charging process and the bulb stayed on while being connected to the USB cable….mine just shuts off as soon as I unscrew the cap.
The battery I’m running in it is a LG HG2 INR18650 LiMn 3000mAh Flat top Battery –35 Amp
When I charge my X5R, I turn it off with the side switch (by double clicking) connect the cable and it turns red. If I then push the tail button the blue led comes on also and it doesn’t charge.
It’s never worked correctly……I just figured it was charging “purple” instead of red, but went to pull the thing out after having charged it overnight (or so I thought), and it was nearly dead.
I typically turn it OFF at the tail switch, plug the USB in (nothing lights up), and then turn the tail switch on. I get the purple light….NO red at all.
If I plug in the USB charger (no light on), it doesn’t glow or anything. The ONLY time it glows “purple” is when I have the USB cable plugged in and I turn on the tail switch. It will however blink RED if the voltage is low like normal.
I appreciate everyone’s suggestions. Kinda sucks, I’ve only had it a month. Great light, even ordered one last week for an in-law that got a promotion. Eager to see what his does. Even ordered a pair of X2R’s for us also.
At first I figured it was the battery, but the battery charges fine on a charger. And then I saw the video of someone pulling the battery out while it was “charging” and the power flowed through and left the light on. Mine just dies immediately when I unscrew the rear cap.
I’ve tried everything…took it apart to make sure all connections were good. Mine will not shut off at all with a double tap of the side button. It won’t charge….
I should have a new X5r today to try, along with X2r’s. We’ll see if this one works as it should. Mine will NOT stay on when plugged to USB………so it’s apparently not getting power cycled through the entire “system” or something. I don’t really know.
