I’ll take one. Gotta see what I need to make a triple.
Please put me down for one copper
I suppose there are many triple builds posts, is there a tutorial post that shows what parts are needed and how it is wired for a noob 0:)
I’d like one of each please. My x6 has a 4C that I really don’t like. Might as well do something ridiculous with it.
+1 for Beachlogger’s request for a noob tutorial.
Hi,
i’m in for 2 copper pills.
Greetings
Kenjii
Hi Nitro,
I would like one copper spacer.
I am leaning toward the no-glass spacer but could change my mind later if you make the with-glass spacer. Can’t make up my mind about that yet.
Does the optic come with a marbled surface? Dale had a smooth one. I don’t know if the smooth one had more OTF lumens or more beam artifacts. If he made it himself, this would have made the lens thinner and maybe he had to use a bigger o-ring underneath to make up the difference?
Here is a start on a parts list for my build (Lord willing of course):
1) X6 host
2) Nitro’s copper heat sink.
3) International Outdoor Ledil Cute-3-SS Triple LED Optic Lens
4) International Outdoor Noctigon XP32 MCPCB & CREE XP-L V6 3D LEDs
5) Mountain Electronics FET + 7135 Driver – 17mm – MTN-17DDm or other hi-power driver.
6) Use Dale’s wire bypass method where he drills a hole in the tailcap switch board and directs a bypass wire straight from the top coil of the spring and down thru the hole to the switch innards. He may need to show us some pics on how that’s done.
Now I just need to contact Bang-good to see if they fixed their shipping problem on their X6 host-only package with loose parts damaging each other in shipment.
All sounds good guys ill have few extra made im sure few will miss out
Nitro, I guess Dale mentioned to you the dimensional differences between the X6-v1 and the X6-v2 (I don’t know if there are also differences between the stainless v2 and the aluminum v2).
Are you going to make heatsinks for either v2 versions in the future or with the upcoming batch (although the v2 dimensions may not have been finalized yet) ?
Also, will the heatsinks have 2 threaded screw holes to hold down the MCPCB or do we just somehow solder the MCPCB to the copper? If soldering is the expected method, what about the unsolderable aluminum heatsinks?
The bezel will press down the mcpcb well enough ![]()
Well i can have the threads done but that's more time and time its money to then lol and these will not fit the new design SSX6 but ill be having done made if the interest is there for them
I can tap the hole for u for a small charge ? We will get in touch when these are done
I made one of these during Nitro’s first run of the spacers, I didn’t think to solder it onto the spacer. I just used Arctic Alumina Thermal Adhesive, put the lens on top, screwed down the head and let the adhesive set.
The new SS/Cu X6 samples will be coming pretty soon, there were enough changes made that it’s anyone’s guess how true it is to the original X6 design. I know the first sample round the inside diameter is larger and the emitter shelf space is smaller, they used a 16mm star instead of a 20mm and we’ve asked that they correct that.
Gluing the sink down with arctic alumina thermal adhesive works well too. I like re-flowing the mcpcb to the sink while mounting the emitters but of course that’s just me.
Long term, cleaning the polycarbonate lens will result in scratches. These scratches will reduce output far more than any glass lens will, so it’s a trade-off when looking at the long term use of a lens vs no lens. I like the lens, a UCLp to be exact, and I do not find any limitation in output. I mean, I’m so happy with 4300 lumens that who cares either way, right? How many pounds of air are in your car tires RIGHT NOW? One psi can change your cars gas mileage and overall performance, do you check it daily? Twice a day? That’s what I thought…
I like the CUTE-4 quad better than the Carclo. The individual TIR’s are much larger, and I’m thinking Cutter is coming out with a new T-Pad that fits it. Need to double check that. The much smaller Carclo 24mm quad is definitely floody, and produces much less lumens. In a smaller light, it’s what works, but in the larger 35mm format then it’s not the best choice. The Convoy M1 I built today getting 3126 lumens from 4 XP-G2 S2 0D de-domed emitters is a good example of when it works. :bigsmile: (custom made head filling copper heat sink, of course)
The CUTE-4 is a killer build, but I really think I prefer the CUTE-3 triple. It’s larger individual TIR’s really perform well with the least amount of wasted space in the X6 head design. Aesthetic’s mean a lot to me, and the look of the CUTE-3 X6 is spectacular. The honeycomb pattern looks really cool, I just like seeing inside the TIR. ![]()
Thanks, this helps a lot
Beachlogger,
This is a bit off-topic but I forgot to mention, regarding the LED/MCPCB assembly, you can purchase the MCPCB separately at…
http://www.mtnelectronics.com/index.php?route=product/product&path=63_64&product_id=401
…and then also purchase the LEDs of your choice separately at the same online store, and have them reflow-soldered onto your MCPCB by Mountain Electronics - this is a free service. This way, you get to choose which type of LEDs you want on the MCPCB board.
However, you will need to drill a small hole in the middle of the MCPCB board so the wires can be routed down the middle. The hole will also be useful in case the outer diameter of the board is a bit too large to fit into the flashlight host’s head. In this situation, you drill the hole (this is Dale’s method) and put a screw though the hole and mount the board/screw onto a drill and spin the board at low drill speed as you slowly remove material from the outer diameter of the board using whatever abrasive (I have never done this before but will probably use fine grit sandpaper super-glued down onto something flat like a piece of wood or metal on the floor or table) and lean the spinning board edge square-down onto the abrasive surface to make it a bit smaller while being careful not to damage the board or LEDs. Beforehand, I will probably also carefully cover the LEDs to keep the grit from settling onto and contaminating the board/LEDs. I may try and ask Mountain Electronics if they are willing to do this for a fee since they have the advantage of doing all of this work BEFORE the LEDs are mounted onto the board. If not, I’m pretty sure most people can do it themselves and it will be more gratifying when there is more DIY effort in any project, as usual.
Maybe your way is the way to go rather than screws. I was thinking of using thermal compound but I figured the screws would squeeze out as much compound as possible for better heatsinking but maybe I’m splitting hairs here - so it may be better and simpler to simply tighten down the head as you said. Thank you for your suggestion.
I wonder if the honeycomb pattern will collect fine dirt in the crevices too.
What about the Khatod 605A optic which is already flat-faced with no honeycomb pattern?
Nitro,
I don’t know if you saw the latest prototype Stainless X6 photos but they look like gems. Dang the $80 which is still a lot of money. Is it ok if I defect from your current heatsink batch list to your (hopefully) future batch list for the stainless X6 instead?
Ok guys i just bought a 6ft 1-1/2 copper rod for this (not cheap) so i hope the interest is still here lol
The Khatod website doesn’t list a 605A that I can find, all of the quads I see are much smaller individual TIR’s, separate in the optic. The CUTE-4 merges larger TIR’s in the middle, enabling a larger lens for each emitter.
It’s a triple, not a quad.
Here is a smooth-faced triple optic by Khatod (35mm diameter x 11.8mm high) “narrow beam”. So its a bit shorter than the Ledil Optic (35mm diameter x 16.5mm high).
With the lower optic height, this will change the heat-sink/spacer dimensions. Or maybe get a thicker Nitro “no-glass-lens-in-front” spacer and make up the difference by putting in a glass UCL and a thicker O-ring.
