Below is our F05 model , the detail information are as below:
New EDC AA XPG2-R5 Flashlight AA flashlight on the 5th battery power
Brand: Hawkeye bulbs: LED maximum brightness (maximum flux): 240-350 lumens
Maximum range: 50 meters outside material: Aluminum Weight: 34.5G
Battery: AA Continuous lighting time: 1-120 Lamp life: 50000
Waterproof: whether rechargeable:
whether the spot: Spot color Category: Black pink Army Green
for the environment: everyday carry camping hiking outdoor projects: Fishing camping hiking traveling by car length: 91.5mm
Highlights:
★ stylish appearance portable
★ classic diamond knurled slip worry
★ stainless steel head to avoid the bump caused by falling
★ integrated circuit positions outside the distinctive arc design, show the graceful lines of the United States. More comfortable grip
★ integrated circuit position after the oxidation of secondary processing, the car lost a lap oxide, aluminum qualities of a perfect match with the barrel, called the crowning touch
★ length of only 91.5mm, weight 34.5G (without batteries). Extreme lightweight
The light is beautiful, but it’s almost imposible to understand the “details”.
You shouldn’t mention the maximum flux of the emitter, but the actual lumens OTF of the flashlight (150 according to the title vs up t 350 emitter max brightness mentioned in the details). Most people won’t care how many lumens can the emitter provide, but prefer to know how many it provides connected to your driver into your flashlight… I don’t like those commercial practices
Sorry, but you descriptions are almost meaningless.
It looks like a nice little light but what on earth does this mean?
Computer translations won't be good enough for trying to establish yourselves in a competitive market on a forum such as this. Perhaps you should contract a native English speaker look over your website. We sometimes enjoy a language puzzle but this will really put a lot of people off.
I suggest you spend some time looking at the way people here review flashlights and then try to provide your information in a similar fashion.
I asked about the F05 yesterday and got this response: Dear Eebowler,
Here is F05 description:
Description: AA Flashlight::
CREE LED XPG2 R51A with 60 000 hours life span
Battery Types Supported: 1 x AA (1.5v) (Output current:High efficient stable transfer )
Material:High hardness,aviation aluminum, abrasion resistance, anti scratch, anti roll.
•Light output:Low-3 Lumens;Mid-40Lumens;High-150 lumens;Strobe-150Lumens;Off
Function:Low/Mide/High//Strobe/Off model
Product Size:91.5MM (length)*20MM(diameter)
Weight:34.5G(without Battery)
Water resistance:IPX8
Impact resistance:1M
Hope this helps. (I asked about price including shipping to the US but EagleEye left that part out and I didn’t ask again)
I can tell this is going to be a learning experience for all involved.
Some questions already asked, translator’s help needed (heck, write the questions for us here in Chinese, see if that helps whoever’s reading it)
— can a lithium-ion rechargeable (4.2v) be used safely? Or only NiMH (1.2v) and alkaline (1.5v)?
— about the driver: is it
—— mode memory (after turned off, comes back on at the same level last in use)?
—— Or no mode (when turned on, always comes on the “first” level?
—— Or “next mode memory” (comes on at a different level than the last one used); use it on high, turn it off, turn it back on and it’s strobing; like that)
More generally — also pass this on in Chinese, if someone can tell whoever’s there who’d decide:
I think all of us readers here would be happy to help improve the translation.
