I have an Eagletac D25C2 mini with a XP-G2 R5 LED. It uses two CR123A batteries.
I was thinking about using two unprotected 16340 Li-ion batteries, 3.7v@1200mAh, instead of two CR123A batteries. I have heard that stacking those types of batteries is unsafe, and not recommended because the voltage jumps up to 7.4vdc. But in series the current stays at 1200mAh. 7.4v x 1.2a = 8.8 watts
I am also buying two Eagletac 18650’s, one to use and the other a spare. The specs says that their Eagletac (of course) 18650 protected button top Li-ion 3.7v 3100mAh batteries are okay to use in the D25C2 mini. 3.7v x 3.1a = 11.47 watts
Pardon my electronics ignorance, but does that mean that using the single 18650 will be brighter than the two 16340 batteries?
Does LED brightness / damage influenced more by watts, or amount of voltage, or current ?
This might be a stupid question, so please enlighten me out of my ignorance.
Thanks!
