Hi all,
I have a 2D Maglite (which I got the wiring and amps all squared out) that uses a plug that screws into the D tube. the front has an opening to hold a 36mm lens which is held in place by pressure from reflector’s. Makes for a Skinny and much shorter Maglite.
You can see my bezel on lower right hand corner of this video.
The bezel is kinda expensive for $30 delivered, but I have no Lathe to machine my own slim Maglite bezel and this route you just make the center hole as big as your reflector requires. Than go to flashlightlens.com and order the appropriate lens…
