You could wire it direct-drive to bypass the driver (and just use the driver board for a battery contact board. You'd have to unsolder the + or - LED wires (whichever goes through driver circuitry rather than directly to battery contact) and resolder them at a spot on the driver board which does directly go to the battery + and - inputs.
Might need some close-up photos of the driver to direct you further.
depending on driver size, you may need a 20mm contact board.
Sorry to say this, but you may have been better getting a convoy c8 host, pick a suitable emitter and driver and build up from there as there can be some issues building up a cheap c8 from what arrived, a host is meant to be assembled so makes life easy.
i have the same one but in XM-L T6, i was going to do review on it…
it’s a very nice light as it is taller than most C8 and can accept 3 AAA batteries ( it came with AAA carrier)
have slightly longer reflector ( dual stage reflector) than most C8 and that translated to tighter hotspot than regular C8, so it makes the light a thrower.
i paid $10/ free shipping, not a bad light at all, although the reflector made out of plastic though.
too bad my C8 XM-L2 pill from lightmalls doesn’t fit into the new ebay C8, or that would make it an awesome thrower:D
I’ve done this, re-configure a C8 or similar light to direct mode, a couple of times, including last night.
I guess I’m more of “a lazy modder” :), and tend to want to do things as simply as possible.
So, what I did in both cases was:
1) Unsolder the + and - wires from the driver board
2) Put a solder blob on the - track of the driver board (facing the battery), close to one edge of the PCB
3) Put another solder blob on the bottom of the spring on the side of the driver board opposite from #2]
4) Take the + wire from the emitter, melt the + blob and solder that wire to the blob
5) Take the - wire from the emitter, melt the - blob and solder that wire to the blob
6) Put the driver back where it came from.
You probably want the + and - wires to come around from the side of the driver board that faces the battery on opposite sides, matching the emitter + and -, so that the wires are long enough.
Doing this, the emitter is driven directly by the battery. One side effect of doing it this way is that the driver is still powered, but if there’s no load (since it’s disconnected from the emitter), I think it doesn’t take much power/current.
Anyway, that’s my “lazy man’s way to direct drive” :)…
Thanks, I tried this now. I tried it before I assembled the light and it worked, but after assemble the light the led was gone… I checked the polarity and the connections seems fine, but the led will not light up. What should I do? Is it easy to destroy a led?
It’s definitely pretty easy to kill an LED… I’ve done it at least once already.
But, I was checking the C8 you linked in the OP, and that has a Q5 emitter, and that was exactly the same emitter that I had in a C8 that I modified last night/this morning to direct drive, so I’m not sure what happened?
You said that you tested the drop-in/light module before assembling, and it worked. At any point after that, up to the point that it stopped working, did you see the LED/emitter flash this kind of dark blue (really briefly) and then fade?
That’s (dark blue flash and then fading) what I saw the one time that I killed an LED :(…
I think the best thing to do is to probably try to determine where you’re at at this point, as a starter…
So:
- Remove the pill from the C8
- Unsolder the red and white wires from the side of the driver board that has the spring
- Get a somewhat discharged 18650 battery (i.e., not fresh off of the charger, but used for awhile)
- Get two jumper wires (with alligator clips, and probably a red and black one), and magnets for the battery, if you can.
- Using a magnet on the - side of the battery, attach the black jumper to the - side of the battery. Then connect the other end of the jumper to the - side of the emitter. The - side usually is close to the edge of the emitter PCB, so I usually CAREFULLY clip directly to the - side of the emitter - if you can’t do that, then clip it to the - wire from the emitter (from your pics, the white wire, I think) ==> So, this is a connection from the - of battery to the - of emitter.
- Using a magnet on the + side of the battery, attach the red jumper to the + side of the battery. ONCE YOU CONNECTED THE RED JUMPER TO THE + SIDE OF THE BATTERY, MAKE SURE THAT THE RED CONNECTOR DOESN’T TOUCH THE BLACK CONNECTOR!! Otherwise, you will be shorting + to - of the battery… not good
- Ok, now one connector of the red jumper is the + of the battery, and the other end of the red jumper is not connected, right?
- Hold the pill with the emitter still (either on a non-metal surface, or just hold it in your hand). Take the other end of the red jumper, and quickly tap the + of the emitter board - DON’T BE LOOKING DIRECTLY AT THE EMITTER WHEN YOU DO THIS!!
- If the emitter is still ok, it should flash briefly.
- If the emitter is dead, it won’t do anything. I usually try this “tapping” test a couple of times, because the + contact on the emitter PCB is kind of tiny, so I miss it a lot, esp. since I’m trying to NOT look at the emitter :)…
Try the above, and post back…
Jim
Edit: Can you post a picture of the side of the driver board that the spring is on? And when you do that, circle the locations where you had connected the red and white wires from the emitter?
I’m not that knowledgeable about LEDs yet, but at the least, a Q5, but actually, since you have to get a new emitter, maybe something like an XM-L2 or XM-L U2 or XM-L2 U2? Those are more recent LEDs, I think, and can also take more forward current.
FYI, looking at the picture, I’m wondering if the exposed part of the red/plus wire might’ve bridged across to the negative (the track around the circumference of the board). Maybe it was ok until a battery was pressing down on the spring, and might’ve contacted either the negative.
I’m still having a hard time coming up with a scenario that would’ve killed the LED. I can see scenarios that might’ve damaged the battery (e.g., shorting the battery + to the battery -), but about the only thing I can think of that might’ve killed the battery is maybe a reverse polarity, i.e., where the negative side of the battery went to to emitter red wire, and the positive side of the battery went to the emitter white wire.
Question: Is the battery that you have a button top or a flat top battery?
Looking at your picture of the spring side of the driver: Is the part where the red wire coming out and then over to the spring as tight as it looks like? Is it possible that it’s so tight that it cut through the red wire insulation?
In the Q5 that I modified last night, there were “notches” or small open areas on each side of the driver board, so when I brought the emitter wires to the front (spring side) of the driver board, they had plenty of room to get through.
If I’m seeing what I think I’m seeing in your pic, that looks like it’s not the case for you. Basically, regardless that you were trying to configure for direct drive, the + lead should only contact where you intend them to, and nowhere else, and ditto for the - lead.
Hopefully someone else will come along, but I think that what you could do is maybe file the board a little to make room for the wire to get through from the back to the front.
