EDC
I know I’m opening a big can of worms, but what is your idea of an ideal EDC light?
Small, pocketable, durable, side -switch with tail-cap lock out or twistie, good modes, reliable, single AA or AAA cell, a reversible side clip so it can be attached to my hat brim as a headlight, a tail cap magnet, small lanyard, good neutral tint.
These below are my favourites:
- Thrunite Ti2
- Olight S15
- Tank007 E09
- a Modded Sipik SK68
- Trustfire Mini-01/02
- a Modded Solarstorm SC01
  • some other modded lights i have)
What he said, with a super bright mode, 300-500 lumens would be nice, i don’t need the magnet though and i want AA an no twistie
Convoy S2 and Enlan EL01 .
I like the KISS philosophy.
the olight i3s is my pocket edc, its tiny enough that you can forget it is there, and you can hand it to a muggle and they know how to use it. the lack of a switch means that you can get some very good waterproofing out of it (gotten it down to 15 feet so far)
It isnt perfect, but it is close enough. I would like more brightness out of it, but I don’t need it, seeing as my murse or my backpack is never very far away, and I always have a knife of some form and a big light in either.
also, the low mode is a good compromise for me between firefly and the higher side of moonlight. I have been n=meaning to get a L3 L10, to try out a AA edc, but have not gotten around to it.
My ideal EDC:
  • Small and light enough to carry in the pocket without being too noticeable.
  • Bright. I like having a pocket rocket I can wow people with.
  • Must also have low and intermediate modes.
  • Runtime is secondary as mostly I’d use an EDC in short bursts. However, it should be able to run for an extended time in medium and low modes.
  • Floody is probably more useful than throw. Though if I can get both in the same light I’ll take it.
  • I prefer a side electronic switch with instant access to moonlight and max.
  • Has to have nice styling. It’s a pocket-toy. I don’t want to be embarrassed to pull it out.
  • li-ion compatible. I like my EDC to be a pocket-rocket. This means using li-ion cells only.
  • water resistance is not necessary. Would be nice if it can survive getting a few drops on it or being rained on. But I never immerse my lights so full waterproofing isn’t necessary.
  • drop resistance. Lights should be able to withstand a 1m drop and still function. I don’t need potted electronics, but competently soldered parts are a must.
For years, my EDC was either a 14500 or 16340 light. However, more recently I’ve been gravitating towards compact 18650 lights for the increased output and greater than 10 minute runtime. My current EDC is my modded Aleto N8 zoomie. It’s a single 18650 zoomie that’s as small as many 14500 zoomies. But it has far more output and runtime, as well as a nice throw mode. I don’t often need throw, but it’s fun to have the option.
Some of the lights that I’ve EDC’d recently:
  • Zebralight SC62w - in my opinion, THE best off-the-shelf EDC light without mods. No other light has come so close to getting everything right.
  • Modded XTAR WK42 - small sideswitch 16340 light. Smaller than a Zebralight SC52. I replaced the guts on mine with an alternate driver, switch and LED. It’s similar in brightness to the SC62w in a much smaller light. Runtime is a lot shorter though.
  • Sinner Cypreus TRI-EDC - equipped with triple XPL neutral and a FET driver. 54 watts of power in a small single-cell triple. On a fresh Samsung 25r this should be outputting close to 4000 lumens. By far my brightest light and it looks beautiful too. Gets hot fast at max power, but fine at moonlight and 25%. Biggest downside for EDC is the all copper construction is much heavier than aluminum. 7.1 oz in the pocket is heavy enough to be noticeable. Second biggest downside is to keep it looking showroom nice, the light needs to be polished every couple weeks.
  • Modded Sipik 58 - equipped with copper heatsink, triple Nichia 219B and 3 amp off-time memory driver. Nice and compact light with great CRI. Downside is the light just doesn’t compare well to the Zebralight SC62w. Both lights are similar in size, but the Zebralight runs at max power much longer and has more throw. Sure the tint on the Sipik is better… but not by much.
  • Modded Aleto N8 zoomie. My modded 18650 zoomie with sideswitch. About the same size as the SC62w. Very comfortable in the pocket with wide, bright flood and good throw. I don’t really need the throw, but it’s fun to EDC a pocket light that produces around 1000 lumens in flood, but can zoom to a throw mode capable of lightning up something up 1,000 feet away. I also have lots of optional parts that I can swap in depending on my mood, including alternate lenses, bezel and tailcap. Swap in the shorter bezel, tailcap and fresnel lens and the light is super-compact with super-wide flood. Swap in the other bezel, aspheric lens and rounded tailcap and it feels better in the hand, looks better, and throws further.
2 cents which doesn’t amount to much , a ZeusRay 7.99$ and stock 900+lumens or a solarforce L-2xx(take your choice of which version)with a modded P60 drop in from Mountain electronics and still under 45.00minus batteries.
Nice looking S2, clip looks great! Nicer looking than my black S2+ Did that come with the holes to attach the clip, or is that modded? Beauty!
Convoy S2 & Kershaw Clash
The S2s come with holes that need no alteration for the clip .
im not a big fan of smaller lights especially AAA sized is waaaay too small in my opinion.
this is what i carry everyday on and off duty.
