Recently I’ve been using my short distance lights a bit more and I keep finding them lacking in different ways.
My 2 channel D4SV2 on the 5700K 519A channel puts out an impressive amount of light but the spot is too narrow and it can’t sustain any decent lumens. Plus cold cct
My boost driver D4V2 2700K 519A with frosty optics is nearly perfectly floody (still would love it to be a tad floodier) can sustain an acceptable output and is beautifully warm but can’t put out all that much light on turbo
Lastly Wurkkos TS22 5000K seems to be closest as it can put out a respectable volley of photons on turbo and also sustain it at a decent level but I’m not in love with the CCT and I prefer wide angle TIR beam profiles with their nice, smooth and gradual spills, less pronounced spot and no harsh cutoff (though this reflector is decent as far as what I’m looking for)
So I’m stumped a bit, looking for something that:
has an impressive top end (3000+ lumens)
can hold a decent stable output without throttling (1000+ lumens as long as the battery lasts would be nice)
comes in a warm CCT (at or below 3000K would be nice)
is as floody as possible, a nice wide angle TIR or equivalent reflector, maybe frosted or dimpled optics, whatever will get me a nice even spill with almost no spot (or an obscenely wide spot of course)
single cell and pocketable (the D4SV2 is pushing it)
I have a D1K with XHP 70.3 HI 4000K (in 70 CRI, nice and rosy, from Hanks"secret" menu), pretty much fits what you are asking for (or the D1, if 21700 is too big). Also available in 3000K.
Almost 3000 lumens, when I did a night walk recently I had it running at level 120 (ceiling, should be around 2000 lumens) and to my surprise it did not throttle at all (at 10°C ambient temperature).
A lot of light in the spill but nevertheless the (huge) spot still packs some punch.
Very happy with the light.
No matter what you end up with, slapping on some diffusion film will give you a hella nice beam.
All my LuxPro lights (hideous G3s behind reflectors) have diffusion film that turns a hideous fried-egg beam into a nice even flood of light.
Ditto with my Tacklife, the beast of a light that’s built like a tank but has a shiite emitter. With diffusion film behind the glass (nonsticky) I use that as my kitchen/basement light for the wide smooth flood of light. (I just wish the UI didn’t suck so bad.)
Removing optix to have a mule is okay, but with a G3 and similar emitters with hideous angular tint-shift, you’ll still be throwing blue in front and yellow off to the sides. Diffusion film hides a multitude of sins.
I don’t think Gs, G2s, Ls, and L2s were too bad, but why take chances? You want smooth flood, you cannot go wring with diffusion film.
DT8K with boost driver? Might not manage quite 3k lm; a D4 is ~2k. Huge choice of LEDs, I’d go to 519A 2700k for your use case. See if Hank has the frosted optics; if not you can swap them yourself and then it’s extremely floody.
If a DT8K’s output isn’t enough, M44 if it isn’t too big.
I’m not exactly convinced a pocket thrower platform with a throwy version of an emitter that is barely floody enough in a shallow orange peel will do the trick . Looks like a great light but I already have my thrower itch scratched (for the time being… )
Do You mean something like the DC Fix? Do You stick it to the inside or the outside of the lens? I’ll have to get some to experiment, thanks for the idea
The FFlite seems like it might do the trick, puts out 3,5k lumens and sustains a bit over 1k with the E21 2000K. Plus it’s basically pure spill no spot, perfect! - Edit: OOS everywhere unfortunately
No direct data for the Emisar, at least I can’t find it. What’s the ordering process? Just email Hank? Also I think the boost driver is incompatible with mules (" The boost driver upgrade is available for the quad version of XP-L HI, SST-20, Osram W1/W2, Nichia 219B R9080 versions, each LED receives 2A current. The driver is not compatible with Nichia E21A, Nichia E17A, and mule versions of the flashlight."
Keep in mind that “throwy” is very relative when it comes to giant emitters like the XHP 70. It only throws well-ish because of the massive amount of lumens it pumps out but it is very much a “wall of light” kind of beam in the small D1/D1K orange peel reflector.
From Your review of the M44 I gather that the sustained output is almost the same regardless if it’s a single 519A channel or two channels going at the same time (and it’s ~20% of the single channel max). And that a single channel max output is about 65% of two channels. That would mean, given 8500 lumen max output for 519A 4500K (I assume on both channels), a single 519A channel will manage ~5500 lumens max output and ~1100 sustained.
And it leaves the other channel up for grabs for a throw or gimmick option (maybe a deep red sst-20? though it’s not on the list of options). But it will end up at about 130-150$, bit pricey
As for the DT8K I see people mention it has the same driver as the D4 boost, so output would be almost the same as my D4V2 boost (output/current is pretty linear and proportional in the 1-2A range).
“Permanent”, I stick the film inside the light, under the glass, if possible. So sticky right on the glass, or nonsticky tucked between glass and reflector.
“Temporary”, or if I can’t get the glass off, then I need the sticky kind, to slap on the outside of the glass.
It will be a little more - driving more LEDs less hard is slightly more thermally efficient and running more current has diminishing returns in terms of output, so it will start a little higher on turbo and won’t thermally throttle quite as far down, but whether the difference would be enough to be perceptible is another question. But with 8 LEDs, a DT8K is floodier than a similarly configured non-mule D4.
high CRI is nice but not necessary
Any ideas what might do the trick?
[/quote]
Everything you want with half the lumens you think you need
