The terrible Twos. 2D LED, 2C LED, 2AA LED Maglite mods.
I haven't done a threesome in a while. Figured it was time again. This is, believe it or not, a short post about what I did.
A little file work always helps.
The 2C (ML25) light uses a new style mounting for the led and the stock light is a twisty design. I drove out the stock pill and I had Dale make a new one, that would fit back in place and also fill the space a dummy cell would be, to get some more mass for heat transfer. I fitted a momentary switch into the side of it and made a switch hole in the body. The LED is an XP-G2 on a 10mm mcpcb and the driver is one of RMM's FET drivers.
The tail cap spring was shortened and put down into the tail cap. I used a cheapy Chinese 26650/18650 sleeve, so I can use an 18650 cell.
For the 2AA, I wanted to keep it working just like the stock light, where you twist down the head to turn it off and twist up the head to turn it on. I had Dale make a pill for this, with the taper of the stock pill and the length to fill where the dummy cell would be. The led is an XP-E2 and the driver is RMM's 12mm FET driver.
This fits and works, but the whole thing will still fall out the bottom, as the stock pill uses a plastic ring to hold it in, so I came up with a copper ring that is glued to the top and the pill will not fall out now.
It also works for a base that the reflector can turn against without hurting the reflector bottom end. The spring did not have to be modified.
The 2D has an MT-G2 led in it, with one of RMM's FET drivers in it. It uses 2x26650 cells and has a sleeve for using 2x18650 cells if desired. I did not do photos, as it is the same method I have used for quite some time. I just gut the stock switch and use the housing for the momentary switch, with a flat round Aluminum heat sink and the driver. I think the video below explains some of it, if necessary.
https://www.youtube.com/watch?v=54JzMlZuur4
I was at work, so the beam shots are not the usual, nor are they very impressive, but all three lights are much brighter than stock. I ended up stippling both the 2D and 2C stock reflectors and sanded the dome of the MT-G2 as well. The 2AA still uses the stock SMO reflector and it is the only "thrower" of the bunch, but it will flat out throw 300 meters+, so that's not too bad for a 2AA Maglight. Not super bright, but a tight beam.
2D MT-G2
2C XP-G2
2AA XP-E2
Unfortunately, none of these pictures do the lights justice, as they are all much brighter than they came out with this crappy camera, or maybe the crappy camera user.
Glam shots
That's all folks.
