Elektro Lumens EDC-XML-R now back in stock
I just wanted to make a post about the Elektro Lumens EDC-XML-R flashlight, which I now have back in stock.
  • EDC-XML-R (Regulation Circuitry)
  • Now using Cree’s newest amazingly bright XM-L2 LED
  • 1000+ Lumens on High Power!!
  • NEW!: Now with regulation circuitry, (with setting memory, always remembers your last setting). At time of purchase you can specify:
  • 1) 2-Mode: Low 10—High 100
  • (2) 3-Mode: Low5—Middle30-High100%
  • (3) 3-Mode: Low5%—High100%—Fast Disabling Strobe
  • (4) 5-Mode: Low10%—Middle30%—High100%—Fast Disabling Strobe—SOS
  • (5) 1-Mode: 100% high mode, no other settings, for those who only need high power. Good choice for Police and Law Enforcement use, military, security, etc.
  • Mode power levels and approximate run times (approximations based on 2800mAh battery capacity):
  • High: 2800mA power level, 1 hour run time, 13000 lux @ 1 meter, 1000+Lumens!!
  • Middle: 800mA power level, 3.5 hours, 3500 lux @ 1 meter
  • Low 5%: 140mA power level, 20 hours, 300 lux @ 1 meter
  • Low 10%: 280mA power level, 10 hours, 600 lux @ 1 meter
  • Dimensions (Approximate)
  • NEW!: Tail cap clicky switch. Reverse clicky as this works best with the circuit. Click on, then press slightly to change mode.
  • Narrow 6 degrees beam, and focused, with very good side spill coverage.
  • 30mm Mineral glass lens, equivalent to UCL clear glass, but mineral glass is stronger and less likely to crack, chip or break
  • Uses a common 18650 Li-Ion rechargable battery. Battery explanation web page (battery not included)
  • Head diameter: 1.5”
  • Body diameter: 1.0”
  • Tail cap diameter: 1.2”
  • Length: 5”
  • Approximate weight without battery: 9 oz.
  • New as of Septemter 15, 2009!!!
  • All parts CNC machined from 6061 aircraft alloy aluminum (Titanium version available, see shopping cart for pricing)
  • Finished in super hard HAIII anodizing, tough, chemical resistant. Sand Blasted and has a semi-gloss finish. I find it difficult to scratch this with a sharp knife, it’s so hard!
  • NEW!: EDC-XML-R is sand blasted, and will come in semi-gloss black. Elektro Lumens EDC-XML-R silk screened to the base of the head in small letters.
  • Made in Grants Pass, Oregon, USA
  • Wayne
If you don’t have one of his lights you need one. They are a built like a tank. I have a older one and its rock solid. Great utility light. Its made to use.
Thanks Ricflair.
Wayne
