Hello all, just droppin' my first post.
Long time lurker/googler.
Any advice along the lines of "flee before you 'Buy Lots of Flashlights (BLF)'" is way too late. I already have 9.
It all started when my and a few of my mates went crabbing and were unhappy about not being able to see anything. Now even when we pitch them 10 metres we track 'em no problems.
Quick list of the gear I currently use: -links to generic stuff for people trying to check out cheap torches.
Ultrafire 504B (post 2010) P60 host - yes I know that the old version with the hex-ring is the 'real' 504B. Whatever, I like this one. It has a glow ring. And stands on it's tail.
+Also have body extension tube to increase burn time.
+Standard Smooth Parabolic Reflector.
P60 drop-ins:
+ XM-L T6 - '1000lm' 1-mode 8.4Vmax
+ XR-E R2 - 300lm 3.0-9.0V
+ XM-L U2 - 880lm 3-mode 2.7-9.0V Solarforce (on it's way)
+ Cree UV - 3.7-4.2V
Trustfire TR-J1 Dive Torch
+ XM-L T6
+ Single 18650 battery powered
+ 4-mode driver.
+ Hall Effect Ring Switch
+ High @ xAmps, Mid @ xAmps, Low @ xAmps
+ Smooth Parabolic Reflector
Generic Maxi Torch - Believe it's called the Ultrafire E3 but mine has no name.
+ Cree XM-L T6 - 1600lm claimed (really 900lm+)
+ Runs on 2x18650 batteries.
+ 5-mode driver (annoying as flies up your nose)
+ Tail-Click Switch
+ Zoomable, Fisheye Lens, Flat Reflector
Generic Mini Torch (to be measured) - link
+ Cree XR-E Q5 bulb - 200lm+ claimed, probs less than 100.
+ Runs on 3xAAA or 1x14500 batteries.
+ 3-mode driver
+ Tail-Click Switch
+ High runs @ xAmps, Low runs @ xAmps
Need to try this one with a 26500 battery. Have a feeling it might fit. If it does, it could mean full burn ccurrent (1000mA) to the LED for a good 4-5hrs
Comes up in eBay searches that include "cree, bike light, q5".
Head Torch(es) - link
+ Cree XM-L T6 bulb - 1400lm claimed
+ 3-mode driver
+ Red Rear-LED on battery pack
These are awesome to use when crabbing, until you turn and face your partner, haha. Slight snow-blindness results.
Batteries
+Panasonic NCR18650 2900mAh, 3100mAh, 3400mAh
+Trustfire Flames 26650 5000mAh(really 4000+mAh)
+Cheapie Blue Labels 18650.
Chargers
+Trustfire TR-001 - Never have I felt like I live life on the edge more than when I'm sitting next to the while it's charging cheapies less than a foot away.
+Nitecore Intellicharge i4 V2.0
Cooling Compound
+Arctic Cool Ceramique 2
Got a few others still coming off the 'Bay.
Plus a few others that I've handed off to friends and crabbing buddies.
Found that unscrewing the reflectors in the pills off even the generic torches with direct contact with housings/hosts and using general (cheap) CPU compound works as well as aluminium(aloomeenum) foil because of better contact area, plus there's no worrying about oxidation or corrosion over time altering your thermal conductivity.
I have dropped all, each and every single one, into at least a metre depth of salt/brackish/swamp water at some point in time. Many of them multiple times. All of them work perfectly fine still. Just pick it up, and keep going. When you get home/have time, give them a wipe with a damp cloth to get rid of the salt and re-lube the threading.
What I don't recommend:
Flashlights that run on single 18650 batteries and have a XM-L LED.
They just burn way too quickly. My best Pana NCR18650s down in a single hour at full burn. Slightly over half an hour for a cheapie blue label. Unless you really only need them occasionally (stashing a flashy in your glovebox, unscrewed of course) and for a short period of time, like to find your dropped car keys, then they're annoyingly useless.
My advice is to pay three or four bucks more, get a double 18650 one, and even cheapie blue labels (around 2000mAh each despite 4000mAh labelling <-lol, oldest scam in the book.) will last a good one and a half hours full burn.
What I'm looking to buy:
Dive/Waterproof Flashlight with a Hall-Effect Ring Switch, powered by 2x26650 batteries, featuring a XM-L 1000+lm array through a zoomable fisheye lens, or reflected by a flat reflector. Under 50AUD.
What I'm looking forward to:
XM-L2. In a 2x26650 host.
Or a nuclear reactor in a battery. Fission or fusion, you choose.
Hope that links to the above don't breach any policy, and thanks to all who post, you've been a great help to me. Or you've just helped me lose my money, haha.
