wolfgirl42
(wolfgirl42)
3
There are multiple kinds of mule. Probably the most common uses 8 3535 LEDs, where they are in parallel, so it has to be the linear driver for them to work. There is also a 16x E21A mule (also linear, same reason). The boost driver needs 4 LEDs in series, so there’s a different PCB. Hank can make a boost mule but it can only use the 4x board, not the others with more LEDs.
