I don’t have a D4V2. I know that is shocking in itself.
Am I correct in my assumption that the boost driver offered in the D4V2 would have a 12-volt output and place the emitters in series with a 2 amp current. (The Emisar specs state each led will get 2 amps maximum… run cooler, less bright than with FET driver).
If that is correct does anyone know what MCPCB is used for series emitters, or if the parallel MCPCB has cut and jumped races?
Correct, 12V with a 4S MCPCB. I don’t see it listed on Hank’s site (only the 4P) but you can probably order the regular 4P one and then email him and request the 4S version.
