giorgoskok
(giorgoskok)
523
Do you agree that it’s an awesome light freeme?
JasonWW
(JasonWW)
524
The only way to make it better is to add a 2 amp usb charger circuit.
giorgoskok
(giorgoskok)
525
“Better” if you don’t want it for it’s small size . Adding a charger circuit will need sone space .
But still a great idea .
JasonWW
(JasonWW)
527
That’s not what I was expecting. Do you have a picture of the light inside it?
freeme
(youtube.com/@1thedeals)
528
Tiny 26650 III looks really like SRK miniature on table. Neutral tint looks pretty good, I would say that it is even better than those end 2016/ 2017 XHP70 NW flashlights. Brightness is excellent for its size without doubts. UI simple and doesn't require much memory work. I could understand why people are crazy it now. I bought black version just to be safe, but i regretted it now as i really curious how it looks in gray.
Victorinox 4.0523.32
Was a tight fit at the beginning but is getting better now.
JasonWW
(JasonWW)
530
Thanks for the pic. It looks hard to remove. I bet I can do a U shaped cut on each side to match the one on the front so I can grab it with 2 fingers and pull it out.
Ig1
(Ig)
531
Interesting light. But as the person who knows very little about soldering drivers and other electronic repairing, looks like I should stay away.
JasonWW
(JasonWW)
532
Why? Are you worried about the button bending if pressed too hard? It can be reinforced without soldering.
RobertB
(RobertB)
533
Thats a handsome pouch right there.
I also thought about doing this cuts but after leaving the light in the holster for couple of days it’s easier to pull it out now.
But beware: don’t order the Victorinox 4.0523.3 (note the missing “2” at the end) - this holster is too small!
RobertB
(RobertB)
536
Mike, you could also stuff that pouch full of damp paper towels, and put it in a ziplock bag for an hour or so. Wrap some painter’s tape around the flashlight to make it slightly larger. Stick it in the pouch and let it dry.
RobertB:
Thanks for the suggestion. I got the holster last weekend and I’ll wait for some more days if it gets loose enough. If not I might try your proposal.
RobertB
(RobertB)
538
These also fit Simon’s Convoy holster fairly well
JasonWW
(JasonWW)
539
This looks like his holster for the S2+ and S3, not for the C8, right?
Looks good too.
Is it the “high quality nylon holster for Convoy S2+/S3 flashlight”?
