I was passing the battery display in Walmart and out of curiosity stopped to see if they had any Duraloops, no the new 'Ion core' have black tops. But I noticed white tops on the Eveready NiMH's in their new 'Smart charger". Forgive the mediocre cellphone photos.
Yes, same as with the former Duraloops, there are black top cells made in China and white top cells made in Japan where the white tops are a registered trademark, so there can be only one manufacturer.
Note that the Eveready Economy charger still has the black top cells, at least on this one display. Check before purchase.
i suspect these are meant to compete with the rayovac and other economy 1400 ish mah cells.
one of the guys at the shop got some and they appear to be oem by sanyo.
havnt run them through the maha c9000 yet……
Errrm, yep, they’re duraloops, it actualy says they Are! below the rechargable writing. And possibly gen3 or 4 too, which is even better for the average shopper now we know they could be releasing g3 or 4 as duraloops. Thanks fyesilova
Edit
I’ve just noticed that pack says they are 2400mah, so they are possibly the black XX eneloops, not just the white eneloops at 1900mah.
Interesting, but no proof. Maybe some could be sent to HKJ and do a comparison under Load... and then a comparison with Discharge, these are more important!!
In Japan, Fuji film is selling eneloop lookalikes, and all dimensions and weight are the same, even specs look identical, but testing them under Load you will see a difference.
Probably discharge rate could be different as well.
ChibiM, duracell wouldn’t put “duraloop” on their packs if it was not duraloop cells inside, that would be false advertisment and would leave them open to being sued and fined by Everyone, and being a worldwide company and well known brand that would be bad business, so it’s pretty much a certainty they have rewraped an eneloop to use for/as their own cells.
Yes It is duralock on the package.
I do not think they will write duraloop on package, and they may change their supplier in future, and that duralock may be written on them too.
