Was looking for something else entirely and spotted this in the adverts
not seen this make before.
even if he claims it is solid the head is made from 3 parts and then likely press fitted it together
SST-50 is an old inefficient LED
zoom with slide and not waterproof sounds like a hell if you ever have gotten water inside
I looked closer and it deems the body is cut in half, so likely screws on the bottom or he press fit copper in the screw holes so opening impossible
I like lights and I like copper but for that money I’d expect to light up the surface of the moon!
The cooper alone would cost over a 100 bucks needed to machine it out.
41 ounces of Copper… wow, thats more than 2 1/2 pounds.
And it sells for $1200… hmmmm thats less than $500 a pound…
here is their site
they have cheaper models that weigh less
http://www.alloylights.com/a1-8-copper
for $200 you can have their 11 ounce model… thats less than $300 per pound of copper… lol!
the price of copper is less than $3 per pound, but if you want it in a flashlight you can pay 100 times more…
Plus its made in USA and takes 23 hours of labor… thats less than $10 per hour for the 11 ounce model… hmmm
somebody with more money than sense, is sure to buy one of those
thanks for the comic relief
Pure copper is about $0.31/oz (9€/kg). Base material from round 1.675” x 6.7” is at least 76 oz (2.15 kg). So they are turning away roughly 50% of the material for only $1000 (900 €).
Sounds legit. ![]()
23hours of labor for such a shitty surface finish on the flat parts, they are kidding
This is machined pretty rough
Lathe to make it round 10 minutes
Use sand paper and polish on lathe 20 minutes
CNC to make it flat 10 minutes
CNC to cut out the guts 15 minutes
Lets say 1 hour labor for the machines extra as their numbers are pretty much single pieces at best a few lights at a time
3 weeks lead time sounds like he sources the machining out to china
1 hour assembly
Poor old inefficient LED
