Finished this up tonight (cause I gotta do mod's that don't require my computer till its fixed next week). A resistor mod was the only change to the factory driver. Did have to do some reflector mod's tho.
Final results 1830Lm with all factory function retained
Interested to know what you used to insulate the reflector from the emitter base? I will be putting an MT-G2 into my Convoy M2 when it arrives and I imagine the reflector will sit over the MT-G2 similar to this one you have done. I have been thinking about what would be the best way to go about it. I am thinking about covering the base of the reflector in kapton tape…
It’s probably work on the F40A, not sure tho, it works on EA41’s but I have never seen an F40A driver or know anything about it. On the subject of these SWM’s, are you the one that replaced their blue 2mm encapsulated emitters with white Nichia’s? I noticed they all had a individual limit resistor, I wonder how far they could be pushed, it’d be nice to be able to use N.119’s (I have tons of them form TP) at about 100-200mA each, I wonder what the driver can handle.
I replace the blue 3mm LEDs (the ones around the center reflector) on my F40A with Warm White 3mm LEDs , but may change them again to U/V mm LEDs for using on out Night Geocaching trips.
Well guy’s somewhat dissapointing news, after having ran it for a few set’s of batteries (thus I imagine giving the emitter a “burn in”) moonlight no longer lights up, thats not to big of a concern for me cause I’m gonna do what DBSAR did and swap my blue 3mm LED’s for white, I’m looking into using SMT N.119’s (on a custom ring PCB) vs 3mm encapsulated.
Other than that its running great, as for runtime on high before overheating, the light has an automatic stepdown around 3min, not sure if its time based or if its doing some sort of temp monitoring but either way, because of it it never gets to hot to hold (note it’s cooled off here, if its still hot where you are you probably shouldn’t set it down attended).
I REALLY like this light, pretty mild mod for me but awesome light, I love the color of the P0’s, the diffuser makes it even nicer, cant wait to go camping again with it.
Also note, the reflector took a LOT of work, had to not only have the hole opened up a good bit but had to be shortened overall.
