OP tested the build with a tame battery that has voltage sag under load. A higher-current cell will most certainly dump more than 12A, and likely sustain the specified 15A for a nontrivial period without losing regulation.
What the Duck did I state?
This is what you stated:
It’s entirely plausible that @paskapotkuri’s light came with a higher-discharge cell, which can allow the buck driver to pull enough current to damage the phosphor.
I was using an LG M50LT cell. The googz says it is Max Continuous Discharge Current: 10A to 14.4A.
Which would make sense that I was getting 12amps with w fet driver.
You obviously have no clue how a single cell buck driver works.
I built it. Has Samsung 50s. I’m very confident in my thermal paste application, but not super confident in the paste itself. From a pc build from 2015. It worked well in my old M21b with xhp70.3 r70 4000k w 6v8a driver.
Its lilely either the emitter doesnt fully like 15a or flux
I’m not saying for certain flux was the problem, but I’ve killed a couple emitters from flux spatter.
Usually the burn marks are bigger, as @L4M4 mentioned.
But I’ve made a habit of cleaning every emitter after all soldering is completed with a brand new nano sponge and 99% iso…gently.
I’ve found these to be best for that specific task.
Very nice! I usually clean my emitters with silicone nanotape–it’s a solid-state adhesive that removes all dirt without leaving any residue. Haven’t run into solder flux spatter very often, but that’s probably because I order mostly bare emitters.
IPA does work magic on flux residue. I once dropped a LHP73B upside down on the MCPCB during reflow and covered the entire phosphor in flux residue. After soaking the surface with IPA and wiping it off with paper towel, the emitter had no issues.
