Sorry guys, but it's another fail, mod is closed, move on to something else...
I just can't stand it any more. The temps are dropping and my hands are itching, (no not from that
), from not having any mods to do.
Can't resist, resistance is futile... I bought a few Maglites when Wal-Mart was having it's sale and most of the stuff I have here was already "in stock" in the O-L workshop, so here I go, doing a mod the way I said I didn't want to. I realize that my style is who I am and like it or not, it is what it is. Either I live with it, or don't, but after trying Celibacy, I just can't get the modder out of the MOM, (Miserable Old Man).
09-30-2013
So I started with a 2D Incandescent Maglite. I had been playing around with cutting grooves in the head and didn't actually have a plan to build it, but I was looking in bins and found a heat sink that I had saved from a previously failed build and decided to build this light as a cut down 1D. I will be using four 14500s in parallel, with a DrJones driver and three XP-G2 leds in parallel.
I'm just using plain 16mm stars with the XP-G2 leds. I will need to reflow them.
I will also be using three 20mm diameter 15 degree TIR optics and I will use the stock plastic lens to make a holder for the optics. I will drill out the holes with a 3/8" drill and then use a #115 Dremel bit to finish out the proper diameter. I'm not worried about the black marker marks not being round, they're just a starting point and they are smaller around than the optics.
I will be adding chips to the DrJones driver. Total of 16 chips @380mA each - 6080mA for three XP-G2s in parallel.
I have gutted the stock switch and I will be keeping the housing and the gutted switch, so I can fit in a momentary.
The momentary switch will be soldered to a 16mm XM-L star and I will use a dremel to open the stock switch up to house the new momentary switch.
I will be using a short spring, so the battery holder will come right up to the end cap and my total distance will be about 75mm.
I have measured out the 75mm and marked it. I will tape it off, as I did on the front end and remove some of the tube to shorten it.
60mm of tube is what I need to take out. The overall length from the back of the switch housing to the tail end of the tube is 145mm and I will need 75mm of that for the new battery holder, but I have to allow for the seam where the tube goes back together. I know that will be 10mm, so overall, I will only take out 60mm instead of 70mm, to allow for the joint.
The heat sink was out of another project, but it will work fine for this one. It's just two pieces of aluminum rod, fitted to go into the head and the top of the body tube.
I want to make a cleaner seam this time, so I am going to try cutting each half of the tube with one of these cutters, with the drill press, so I can get a good clean, even cut. Using a hacksaw and files does not always leave a clean and neat seam... The top cutter is for making the seam, inside of one piece and outside of the other. I also have to allow for boring the tube, so clearances will have to be exact!
One piece cut off with the hacksaw, so I can take it over to the drill press.
This is the cutting wheel I am using and I will hopefully cut a clean cut with it.
Well, it worked really good. This way I have a seam that will be hard to see.
Like I said, it's going to be hard to see the seam once it's done.
I still have a lot to go, so... have fun till I get more done.
