Failed mod - xhp70.3 barely lights up
I am pretty new to modding and looking for help finding what I did wrong trying to install a xhp70.3 6v paired with a Convoy 6v boost driver.
After soldering the wires to the mcpcb I went to test the light and the LED barely lit up at all, and was flickering very slightly. When I half press the tail switch it flashes off like it’s switching modes but then stays the same very dim level of brightness. I tried resoldering the wires to make sure the connection is secure and it does feel solid.
I don’t have any other 6v LEDs or drivers to try to test which component is the issue, and am at a loss for what to do differently.
Any help is appreciated.
The xhp70.3 can be either 6 volt or 12 volt. Does the voltage of the emitter you have match the output voltage of the emitter? Is the led 12 volts and the driver putting out 6 volts?
Ah I realized I was confusing amps and volts in my post, but according to the receipts both are 6 volts.
Sometimes this can happen if the reflow is bad, i.e., the electrical connection between the LED and the board is not good. Maybe test the LED with a multimeter to see if it lights up right? If it flickers or lights up uneven it’s probably a reflow problem.
Hey mate is it the 22mm 6v 8amp driver? mine is doing the same thing, it was working at the start but it would not switch to turbo mode.
What host? Can you post a pic of the mcpcb as installed in the light?
This may not work. I don’t know how common this is, but my DMM can only check 3V LEDs, not 6/12.
No, it’s the 17mm 6v 5a driver.
I initially tried it in a Convoy S8 but it didn’t fit (driver was too tall), so now it’s in a Convoy C8. I can post a picture tonight.
Thanks, I’ll have to look up how to do that and if my multimeter can do it.
Okay cool i have some of them and i will test them, its the exact same problem i am having, i thought the driver might be sensing high resistance in the circuit so it won’t run turbo properly but i eliminated anything that would cause that and it was still having issues. I will test mine out tonight and see what i find.
Also make sure the retaining ring is tight and touching the outer contact ring of the driver, and not touching any driver components (and that the driver doesn’t wiggle around). It’s a pretty packed driver and the ring could be shorting something. Maybe post a pic of the driver too.
I suspect the same. The retaining ring might be too wide and shorting something on the driver. In the worst case, dremel the ring to make it thinner as you can’t solder the driver to the shelf unlike in a brass pill host.
I can’t speak for op but I don’t think that would be the issue as the light might not turn on at all if it’s shorted on the back of the PCB.
It doesn’t look like the ring is touching any driver components to me, and the ring is tightened down decently snug, no movement of the driver that I can perceive.
Does it work normally without the reflector? You should really be using a 20mm mcpcb so there’s less risk of shorting the wires with the underside of the reflector.
No, it behaves the same with or without the reflector, it’s that same very very dim output regardless. The only reason it’s on a 16mm MCPCB is that I initially got this emitter for a Convoy S8 before finding out the driver didn’t fit.
Very strange. I’m about out of ideas. One last thing though, can you get into the mode group change menu? Are you familiar with that? Half-press a bunch of times until it starts flashing rapidly. Then try to change to any other group. Maybe if there’s a firmware problem that can sort of reset it.
I just tried it and it does seem to work, I turned memory off and changed the mode group but still the same super dim output.
This is a silly one but I have to ask, battery is charged, right?
Always a fair question, but yes haha I just double checked.
