Fandyfire STL-V3 ....... lost modes??
Noticed last night that my regular ‘dogging’ torch [as in dog walking … not the ‘other’ dogging :wink: ] would not work on high, and also lost the SOS mode [not that i use it] …
I put it down to low battery, but out again tonight with a fresh fully charged battery and it’s still the same :frowning:
Tried yet another full battery just now, but to no avail …. it now only works on mid, low and fast strobe.
Any ideas
Have you checked the pill has not worked loose?
Had it apart before posting … no obvious cause, all appears as it should. Tried the pill but cant move that, tightly fitted.
Its not the switch either, tried another on there, made no difference :frowning:
So that only leaves a fault on the driver i assume … just my luck :~
Oh well …. time to buy another torch lol :bigsmile:
You know, that looks really similar to my uf-v3…
When I removed the driver from my m10, I fitted it in there, I have another driver from an m10, I could drop it in the box with your a60 if you wanted, let you have a play… It’ll be going begging anyway so why not use it. 8)
Worth a try … thanks mate :slight_smile:
[But i’ll still use it as an excuse to buy another torch] :wink:
Well, it might not work……you need to cover that eventuality…. 0:)
Feckin thing lol …
Last night’s dog walk, still only works on Mid/low/fast strobe.
Out on this morning’s dogging before work …… bloody thing has all 5 modes back now!
I’ve done nothing to it, not even replaced current battery …………… baffling :~
Lets see how long it lasts …………………………
