Anybody know where I can get a couple of fans (9-10”) that use 18650’s?
I live in Florida-getting ready for power outages.
Under $20?
I got this one: EasyAcc USB Desk Fan
It comes with a genuine 2600mAh 18650 cell (at least when I purchased it), from LG if I remember correctly. The space is somewhat tight so it will only work with a flat top, but the second I purchased later was a bit less tight, maybe a button top may still work with it. There are other fans that run on 18650s, but I’m not sure of the bundled cell quality for them.
Edit: the new 3350mAh “2020” version has a non-removable battery according to a review, but the 2600mAh can still be purchased.
I purchased this and like it quite a bit. $28 now, I think I paid around $25 . The price might fluctuate on AMZ.
https://www.amazon.com/gp/product/B07CP3C2L3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Comes with two unprotected 18650s that I tested. They came out pretty close to specs. The batteries run parallel. I think you can run it off just one battery, I’ll have to check.
The fans battery case wouldn’t fit my protected 18650s, just the unprotected ones.
Have you considered 12 volt truck or RV fans?
Truck fans up to about 8 inches often have a spring loaded clip used for attaching them to a flip down windshield visor but could just as easily grab onto the edge of a shelf, chair back, table edge, or whatever else is handy.
There are several decent models in your price range.
Would be easy to run one from a small multi 18650 power bank “kit” that runs from user supplied 18650 cells and has a 12 volt output jack.
