fasttech
(fasttech)
1061
SMILING SHARK E215-2 Mini LED Flashlight
1*Luminus SST20 / 7-mode / 1200LM / pure white / 1*16340/1*18650 / IPX6 waterproof
fasttech
(fasttech)
1062
MATEMINCO CSF-04 USB-C Rechargeable EDC LED Flashlight
1*main LED+3*auxiliary LED / multiple modes / 300LM / pure white+blue+red+UV light / smooth ramping / IP65 / glow resinous material
Operation:
In shutdown mode
Single Click to return to the stepless dimming memory mode
Long press to enter stepless dimming, the default minimum brightness, long press until turbo light
Double click to enter the strobe mode
Triple click to enter the auxiliary function light mode. Default UV/white light, single click to enter the red light, single click to enter the blue light, single click to enter the red light flashing, single click to enter the blue light flashing, single click to enter the red and blue alternate flashing
Four click to enter the voltage detection mode
Five click to enter the locked mode, five click again to unlock
Six click to enter RGB breathing light switch mode
Seven click to restore factory settings
In boot mode
Double click turbo light
Long press stepless dimming
fasttech
(fasttech)
1063
Authentic HaikeLite HK04 Anduril UI Super Bright LED Flashlight
4*Cree XP-L HI / 2-mode (stepless/step dimming) / 5000LM / cool white / 3*18650 / USB-C rechargeable / IPX7 waterproof
Intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 56mm
Tube diameter: 46mm
Tail diameter: 50mm
Charging: 5V / 3A fast charging (When flashlight is charging, the switch lights up red; when charging is complete, the switch lights blue)
zoulas
(zoulas)
1064
I love how they use the word “Authentic” as if it was a feature. Its sad when there are so many fakes out there that companies need to explicitly state the product is authentic.
fasttech
(fasttech)
1065
Authentic Fenix E35 V3.0 LED Flashlight
1*Luminus SST70 LED / 5-mode / 3000LM / cool white / 1*21700 / USB rechargeable / lanyard / IP68 waterproof (2m underwater)
Head diameter: 26.5mm
Voltage: 3.7-4.2V
fasttech
(fasttech)
1066
Authentic JETBeam RRT-M1X White Laser LED Flashlight
1*WP-T2 LED / 5-mode / 480LM / pure white / 1*18650/1*21700 / lanyard / IPX8 waterproof (2m underwater)
Input coupon code *MAP *in the shopping cart page to see our unbeatable price
Reflector diameter: 53mm
Head diameter: 61mm
Tube diameter: 28.3mm
Tail diameter: 28.3mm
Voltage: 3.7-4.2V
fasttech
(fasttech)
1067
Authentic KLARUS XT2CR PRO LED Flashlight
1*Cree XHP35 HD / 6-mode / 2100LM / pure white / 1*18650/2*CR123A / clip / lanyard / IPX8 waterproof
Reflector diameter: 20mm
Head diameter: 25.4mm
Tube diameter: 28mm
Working voltage: 2.8-6.4V
fasttech
(fasttech)
1068
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*LED / 6-mode / 3000LM / pure white / 1*20350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
fasttech
(fasttech)
1069
UniqueFire UF-1502 LED Flashlight w/ Focus Zoom
authentic / Cree XM-L2 / 5-mode / 1200LM / 6500K / 2*18650 / lanyard
Head diameter: 43mm
Tube diameter: 24.8mm
Tail diameter: 30.6mm
Lanyard length: 18cm
Beam range: 100-200m
Waterproof in accordance with IPX8 (submersible to 2 meters underwater)
Working voltage: 7.4-8.4V
Rotates the head to zoom in/out
fasttech
(fasttech)
1070
Authentic KLARUS XT21C LED Flashlight
1*Luminus SST70 LED / 6-mode / 3200LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof
Working voltage: 2.8-4.2V
Light intensity: 26280cd
Head diameter: 35mm
Tail diameter: 25.4mm
fasttech
(fasttech)
1071
LX200 Hand Wave Activated LED Headlamp
1*LED + 1*COB / 4-mode / 350LM / pure white / USB rechargeable / IPX4 waterproof
Don’t forget to enter coupon code MAP in the shopping cart page to see our unbeatable price at $11.65.
Working voltage: 3.0V-4.5V
Irradiation area: >50 square meters
fasttech
(fasttech)
1072
2PCS SMILING SHARK 657 Mini LED Flashlight
1*LED / 3-mode / 80LM / pure white / 1*18650 / 1200mAh power bank / IPX6 waterproof
fasttech
(fasttech)
1073
Authentic Fenix PD35 V2.0 LED Flashlight
1*Cree XP-L HI V3 / 6-mode / 1000LM / white light / 1*18650/2*CR123A
PD35 V2.0 is a handy and delicate flashlight. Fitted with Cree XP-L HI V3 LED, it delivers a max output of 1000 lumens and a far-reaching distance of 250 meters. This compact but tough flashlight features five output levels, plus instant strobe, battery level indication is fitted as well. Powered by one 18650 rechargeable Li-ion battery, it is also compatible with cold-resistant CR123A battery. The dual switches design - tactical tail switch and metal side switch, offers rapid and user-friendly operation. All these highlights make PD35 V2.0 very suitable for military use, policing, outdoor exploring, emergency lighting and even more.
Tube diameter: 23mm
Working voltage: 1.8-3.7V
Beam range: 250 meters
Boot-up battery level indication and low-voltage warning
Digitally regulated output maintains constant brightness
Reverse polarity protection, protects from improper battery insertion
Anti-roll and anti-slip body design
Tactical tail switch features instant activation
Metal side switch for output selection
fasttech
(fasttech)
1074
Outdoor USB Rechargeable LED Headlamp
1*Cree XM-L2 + 2*LED / 11-mode / 750LM / white+blue+red light / 1*18650 / 180’ rotatable lamphead
fasttech
(fasttech)
1075
What an exceiting News! FastTech 9th Anniversary is coming! To celebrate the 9th anniversary of FastTech, we’ll prepare a discount of 15% Site-wide and there are more surprises waiting for you! Are you ready?
————————- Anniversary Site-Wide Coupon ———————————
Offer: Site-wide 15% off
Valid Date: Jun 2, 2021 (UTC-6)
Coupon Code: FASTTECH2021
Click here to know more information of the anniversary promotion: FastTech 9th Anniversary 15% off Site-Wide
Does order history gets deleted after a few years?
Paypal/ebay does the same thing it’s just an inconvenience.
fasttech
(fasttech)
1078
Yes, customers maybe can’t find orders placed a few years ago in their accounts. If you need to check any of your old orders, you can contact us via ticket, our customer service representatives will try the best to provide the order information to you.
fasttech
(fasttech)
1079
fasttech
(fasttech)
1080
F401 3*LED 6-Mode 5000LM LED Flashlight
pure white / 4*18650 / IPX5 waterproof / OLED display / stepless dimming / power bank function
6-mode: Long press for 3 seconds to turn on. Strong light-medium light-low light (double click) turbo~~(single click) strobe~~(single click) low light single click to shut down
Any mode stays for more than 8 seconds, it is shutdown
Long press the switch after power on is the stepless dimming function, the light flashes twice when it is adjusted to the brightest, and twice when it is the weakest
Temperature protection and short circuit protection
Automatic power off under low voltage
