I have two that melted the spring like this. Is this common? Are they easily [budget pricing]repairable?
I was sold on the hot red color ![]()
Had so many SRKs - none of them had this issue.
collapsed spring = dead short? maybe?
You can replace the spring with a soldering iron but you’ll want o find out why it happened before you light it up again.
Not a problem I’ve had or heard of people having. I can’t really imagine what would cause it apart from a battery being a dead short, which is again a problem I’ve not come across. It would take a lot of current to do that to a spring.
The springs are cheap enough from Mountain Electronics or Fasttech. I’d try a repair. You may need to fix on a copper pad to solder to and put in connections to repair the board.
As Rufusduck said, find out why it happened rather than just steam ahead with new springs. I’d check the batteries over.
Something I find odd is that you say this has happened to a couple of lights. Is there something common to them such as the batteries used?
Thanks for all the replies… Yes the batteries are what’s in common. As I recall they were 2-3 buck samsung batteries.
When inserted the light got warm.
I have a Nightcore charger… How do I check for a dead short?
I’m not familiar with Nitecore chargers and what they can do, so I don’t know how it can cope with a shorted cell, but I suppose it’s designed in.
There are four cells in parallel in the SRK and were one to become a short the others would discharge through it very fast. I’d expect the shorted battery to show signs of damage, show no voltage as checked with a multimeter, and be impossible to charge.
I suppose you could get a single cell shorting itself from the positive contact of a cell to the body of the light somehow and have one of the cells shorted that way, so also look at the top of the batteries and the contact board in the head of the SRK. Also, I’d have thought that an unprotected 18650 which had been shorted to burn out a spring would be discharged well past its lower limit and be finished.
The short may have caused the 18650 to go open circuit rather than stay a short, as it burned out something in the battery.
All guesswork really. I’ve never shorted an 18650 or had one go short circuit on its own.
Are they flat top batteries?
