I got to say Foy has it right, my favorite edc is the L2M and the L2. I’ve put 3 amp Intl-Outdoor dropins in each, both also with the A001 head. Then I used oversized O-rings and Teflon tape on the head threads. IMR 18350 in the shorty and a 3100 mah in the regular. Both spent 2 days at the bottom of the pool and no sign of water in either. Both also mount very well on my rifle or shotgun.
I’m with Texas Shooter. Yes, Foy has it about right for me as well. I want an A001 head, badly.
But for now, I have an L2M I built myself from a 1x123a body tube (marked “L2M”) with an HAIII head and an older style fatty tailcap with laynard holes. It’s has a MF UF 3-mode XM-L T6 that hits right close to 3A with a TFF 18340 cell.
Also often carry my self-built L2T with the same HAIII head, an HAIII tailstand tailcap, also loaded with the same MF UF 3-mode drop-in powered to 3A with a TFF 18650 3100mAh cell or a SolarForce V3 2600mAh cell.
L2TJaffo on the right:
Also, I always have my Trustfire Mini-01 running off a TFF 16350 with me almost unnoticeable in my other pocket. And yes, the two larger lights fit just fine in the pocket as well.
… The maratac cu aaa.
I will be giving the uf-t50 a go this winter (coat friendly).
Either a SK68 on eneloops or 14500 or 501a with a XTE R5 3 mode with a SF 16340 in it.
SK68 for LIFE
An iTP SA1 Eluma with AW 14500 most of the time, occasionally an L2P with an E1320 NW 5 mode drop in and AW 18650.
I'm with Boaz. AAA or AA for me.
Eoslamp SP11
Nitecore EC1 I guess, since it is my EDC.
Looks smaller than I imaged compared to your keys.
Im very tempted to get one but trying to talk myself out of it.
E1320 14500 with 3C XML @ 3.55 amps .
Jaffo - I dig that L2M with the S4. Never would have thought that would look good.
And Jack's 3.55 amp handyhomehowitzer wins the pocket/jewels igniter award.
daymFoy
It's been a great little light.
Xeno E03 with 14500 battery. I also have an L2M but it’s a little too big on my pocket.
Xeno E03 XM-L for me too.
whoa these are in ‘production’ already??
sc600 for me
Jack’s hot rod was the guinea pig, if it didn’t cause an emergency in his pants or burst into flames than I shall proceed making some more limited to 2.8 amps on turbo of course.
As far as EDC I still carry my Black Cat and my XML A30B
DQG AA anyone? :)
Nitecore D10 and one of these:
Hello BLFers, I'd like to bring you one special SS AAA light, it's probably the thinest AAA EDC in the world, only has a diameter of 11.5mm. We'll release a batch of 100 pieces with BLF logo on it. http://www.cnqualitygoods.com/goods.php?id=1287 [image] Specs: Using CREE XP-E R3 CW/NW Material: 304 SS Reflector: Aluminum Alloy OP reflector Glass Lens Switch: Stainless Steel tailcap click Single mode Brightness: Hi--80lumens Current drawn: 210mA Battery: 1.2v AAA ;Anti…
Apparently they are called CQG S1, I did not know this until now ![]()
