I am looking to up the ante on this little light…
Overall goals:
>more lumens on hi
>less lumens on low
>last mode memory
>no PWM
>maximum lumens per watt efficiency
>Efest purple IMR cells are my preference, and I have no need for NiMH or alkaline compatibility
I am leaning towards the Adventure sport driver. I like all its seprate-able mode groups so disco is clearly out of the way of everything else. I will have to sand it down to 16.5mm to fit the TG06 pill. Knowing the thermal limits of a host this small, I suspect the brightest modes will be for short bursts only… which is perfectly OK by me. The OEM TG06 driver is single sided only. I am trying to keep things that way if possible.
http://asflashlights.com/-diy-parts/75-10-amp-capable-17mm-led-driver.html
I want to replace the XP-G2 with something brighter. I am not sure if I can use the XP-L HI linked below…. Anyone have any feedback in this regard? The TG06 has a smooth reflector so I want as much of a bright hot spot as possible.
http://www.mtnelectronics.com/index.php?route=product/product&path=60_106&product_id=793
thanks and happy new year BLF!!
