I wouldn’t put a single 219b on a FET/DD driver of any sort. The risk of overdriving that emitter is quite great, even if you attempt to add extra resistance. Too risky and unpredictable. For me, at least.
I see two options:
1. Mod one of those drivers. If they’re 3-channel drivers, the type with a single 7135 channel, a multi-7135 channel, then the FET, you can just flick the FET off the board so it’ll never engage. This will limit your total power output to the 7135 banks, which is probably 7 or 8 chips (2.7-3 amps, assuming the firmware fully engages all channels on turbo). It’ll also make your firmware feel funky because the mode spacing will be all wrong, but it’ll work.
2. Buy a new driver. This is what I would do. Qlites are fine and 3 amps is good, assuming your build has a good thermal path to cool that emitter. Personally, my single 219b setups (which is something I use very often, there’s one in my pocket today) currently have LD-4 drivers from Neven, led4power.com. Constant current FTW :slight_smile:
