Feeler: 16mm copper sinkpads
I created my first pcb layout just recently, so i don’t have any experience. But if noone else comes forward with a XP-G layout, i can try to provide one. It would definitely need review, though.
Thoughts ???
Are there 2 holes + the notches cut on the side? JW what the reason behind this is? I don’t have much experience with other lights besides p60 drop ins
The two holes will not be that large but those are for the mounting screws, and yes there will be 2 notches on the side to run your wire to the solder pads
The holes will be exactly that size. That was the size (#4 Screw Clearance) you asked me to add.
Maybe it’s just the pic on my phone it looks large :slight_smile:
The further the negative and positive pads are to the outer diameter the better clearance you will have on any reflector to prevent shorts.
+1
Wire cut-outs and holes for mounting screws are simply too large. Even solder pads could be a little smaller (narrower).
I agree but there are pros and cons. Further out leaves more room for optic or spacer, further in favors trimming. I’m undecided on them as I use 20 mm boards for AA mods and 10 mm boards for solitaires but leaning towards a buy of ten pcs just to help get them done. Overall, I’d favor pads farther out since one can always scrape the trace area for more pad to move it in but you can’t move it out.
Nitro I would interested in at least 1
