I picked up the HL21 during Wallbuys xmas sale.
On first use I was unimpressed. The xpe beam throws well but is very cool white.
So, I took it apart. I had hoped to use an xml2, but found that the mcpcb is unique, so I took an xpg2 r5 3d (5000k) from illumination supply off the mcpcb it came on and reflowed it to the mcpcb for the HL21.
Now I like it - a LOT. Hot spot is less pronounced, still plenty of throw, and it now has the tint that a headlamp should have…what a difference.
For anyone else looking to mod this light, here are my two main tips.
-when you pry the back off, start near the battery tube. Get it ajar, then use your fingers instead of a tool, to avoid damaging the delicate lip that goes around the edge. Or, just say screw it (like I did). Get that edge all buggered up and when you’re done, just glue it back on and forget about it.
the leads that go to the emitter pass through a piece of aluminum mark which hole has the red/black lead so that you can reassemble it the same way. if you don’t, when you screw it back together they could be the opposite of where you’d like them.
and, a few photos/instructions
pry the back off
unsolder the leads from the board, lift the board out
remove the head - heat it first - I used a glass cooktop, set to almost lowest setting and with the head of the light facedown near the edge of the hotspot, then gripped with non-marring pliers and unscrewed.
Unscrew the bare aluminum part from the black part of the head. This required more heat than removing it from the body. Non-marring pliers on the black part, snap ring pliers in the emitter lead holes (NOT the other holes). Be patient, mine was glued together pretty securely…
thats all folks
